Common Ground Switch(Generator Mode) & Adding a Generator Coil - Observations
  • pearldragon
    Hi Gary, RS,
    3rd set of Coils Shortening tests done see attached file.
    Curious to hear what you think of the zoomed in signals of the reed switch, page 51.
    Best regards,
    Rodolphe
    Generator coil tests - Report 3 - V1.0 - ESF.pdf
  • pearldragon
    Hi Gary, RS,
    I've done a second set of tests, with loads and an corrected MOSFET circuit for the Hall sensor. For the report/my findings please see attached file.
    Best regards,
    Rodolphe
    2021-01-23 - Generator coil Tests w. 10k Load V1.0 - ESF.pdf
  • Gary Hammond
    Hi Rodolphe,
    not sure if I understand you correctly here: with a "point and condenser" system you mean a Reed Switch?
    No, I didn't mean a reed switch. I was referring to the ignition system of a small, single cylinder, gasoline engine as used in lawn mowers and chain saws, etc.
    Older designs use breaker points to short out the primary coil winding until the flywheel magnet is directly over the coil. At that moment in rotation, the points open to stop current flow and produce moderately high voltage from the coil current (induced magnetic field) collapse. The capacitor, in parallel with the breaker points, reduces arcing across the points. The moderately high voltage then induces a much higher voltage in the secondary winding of the coil, which is able to fire a spark plug under high pressure in the cylinder.
    The breaker points and condenser can be replaced by a simple solid state ignition module which is much more reliable. These ignition modules were available in kit form to retrofit most any small engine. I installed and/or sold several of these years ago. Nearly all small engines now have this module embedded in the coil as standard equipment.
    Gary Hammond,
  • pearldragon
    Hi Gary, RS,
    I've done a first set of tests, for the report/my findings please see attached file.
    The point and condenser system can be troublesome, so I frequently eliminated them in favor of a solid state switching module which was very reliable.
    not sure if I understand you correctly here: with a "point and consenser" system you mean a Reed Switch?
    Bets regards,
    Rodolphe
    2021-01-06 - Generator coil Tests V1.1.pdf
    UPDATE 2021-01-22
    -Added an addendum for the HALL sensor circuit
    Attachment UPDATE 2021-01-22.pdf
    Last edited by pearldragon; 01-22-2021, 03:55 AM. Reason: Added an updated Hall sensor circuit
  • pearldragon
    Hi Gary Thanks For your answers!
    Today I've ordered some reed switched and some Hall effect sensors too. The rest of the stuff I already had at home. Will do a series of experiments, and update here once done. But it will take me a while.
    Rodolphe
  • Gary Hammond
    Hi Rodolphe,
    1-
    Is this because the amperage in the short-circuit can exceed the Reed-Switch rating?
    I would assume that is correct.
    How about a Hall sensor?
    I have seen circuits where people have used hall switches to trigger either a FET or an SCR.
    2a-
    Assuming I would need indirect switching for the Reed switch (/hall sensor) to live longer, would the schematic as per Figure 2 work?
    What you show looks reasonable, but I would have to build and test it to know for sure.
    2b-
    Would an SCR (instead of a MOSFET) or another switching device be better suited here?
    An SCR latches on until the polarity either falls to zero or reverses. Without trying it, I don't know whether it would work without some extra circuit components.
    3-
    Would I be able to achieve even more output from the generator coil (=charging the capacitor to higher voltage) if I would use an individual trigger coil
    to operate the MOSFET, see Figure 3
    Don't know the answer to this. You would have to try both ways and then compare results.
    I've not experimented with generator coil shorting circuits myself, so am not a good source for information on the subject. I do know that this is the principle used in magnetos which I do have some experience with on small engines. The point and condenser system can be troublesome, so I frequently eliminated them in favor of a solid state switching module which was very reliable. Could one of these ignition modules be used with the generator coils? I don't know as I haven't tried it myself.
    Gary Hammond,
  • pearldragon
    Hi Gary, RS,
    I was a bit in doubt in which thread to post the following questions, but it think is not a bad choice.
    I actually wanted to wait with learning/experimenting about the generator coil till I have my SG in the ballpark of your SG, performance wise, but since I’m still waiting for parts, decided to make the preparations for some testing with the generator coil, which I attached to my SG.
    Apart from the tests as described on page 41 of the Advances Handbook, and the slightly modified version in your post 11, I would like to do the experiments that Aaron shows in his video: https://www.youtube.com/watch?v=s6iYRjcBu-Q
    1- If I understand correctly, his circuit looks like figure 1, as in the attachment. Now he mentions that it is not recommended to switch/short-circuit the generator coil directly with a Reed Switch. Is this because the amperage in the short-circuit can exceed the Reed-Switch rating? I also saw that there are Reed Relays available too with a higher amp rating, but switching time becomes critical with my 21 magnet rotor it seems. How about a Hall sensor?
    2a- Assuming I would need indirect switching for the Reed switch (/hall sensor) to live longer, would the schematic as per Figure 2 work?
    2b- Would an SCR (instead of a MOSFET) or another switching device be better suited here?
    3-Would I be able to achieve even more output from the generator coil (=charging the capacitor to higher voltage) if I would use an individual trigger coil
    Rodolphe
    2020-12-22 Attachment.pdf
  • pearldragon
    Hi Gary,
    Thanks for your explanation regarding the workings of the different diodes. I haven't looked at the "Beyond The Advanced Handbook" yet, but i did bought it already.
    I use a 100 ohm, 25 watt, single turn potmeter in all my builds now. I've burned out a few low wattage pots, so I tend to go for a little overkill with them.
    Ok, thanks. I guess since my 2W potmeter hasn't burned out yet, any fixed resister with at least a 2W rating should be good (and if not, I'll find out pretty quick too ).
    Thanks!
    Regards,
    Rodolphe
  • Gary Hammond
    Hi Rodolphe,
    Could you maybe explain me in a bit more detail how using one of these UF diodes would yield better results? Is there a specific reason why you did not use them yourself? Or did you wanted to stick to the handbooks first before interchanging parts?
    This was a generalization and may not really matter at this particular location in the circuit. You can also eliminate the diode altogether for fastest charging if the secondary is only 6/10 volt less than the primary at the start. The two batteries are essentially in parallel with each other and will equalize voltage between the two through the power coil ....... minus the forward voltage drop across the charging diodes. If the extra diode is added, the combined forward voltage drop is 1.2 volts and allows for charging a secondary battery that is 1.2 volts lower than the primary without voltage equalization taking place. But equalization isn't all bad, because it results in faster charging of the secondary. And once the secondary battery voltage exceeds that of the primary the current draw falls off any way.
    Peter Lindemann has pointed out that the ultra fast diodes attached to the collector/power coil junction deliver a higher voltage and faster charging to the secondary battery than the slower speed diodes. The slower speed diodes (1N4007), however, kick back more energy to the primary battery resulting in less current draw and a longer run time. So it is sort of a trade off and up to you which way you want to go. Faster charging of the secondary vs longer run time from the primary battery.
    Peter also demonstrated what an ultra fast diode added to the battery swapping circuit in his "Beyond The Advanced Handbook" presentation does. It caused the radiant energy to manifest at all points in the circuit causing the neons across the transistors to light up brightly! The volt meters across the batteries were glitching and sometimes going off scale! Of course this was operating at 24 volts and not the usual 12 volts everyone starts out with.
    I did use a MUR3020WT ultra fast diode in the attraction motor I made, and it charges the secondary very fast. I also used a UF4007 in the SSG driving the two-stage mechanical oscillator my grandson and I built. It also charges pretty fast. But I didn't want to go back and change out all the diodes in the other SSGs that I already had built previously.
    Since up to this point I’m still working with my potmeter* from the Intermediate Handbook without any problems, I assume the 12-Ohms resistors didn’t need to be 10W, and neither is there a reason for using a 25W potmeter if a 1W is sufficient?
    Gary Hammond,
  • pearldragon
    Hi Gary,
    UF Diodes
    An ultra-fast switching diode here would be desirable. Two UF4007 diodes in parallel would be able to handle up to 2 amps, and a MUR3020WT would be able to handle up to 30 amps.
    Power rating (variable) resistance
    I’m planning to do some of my own measurements on the efficiency of single/double pulsing area/rpms. To do that I want to build in some form of the “trigger switch”, as mentioned on page16/17 of the Advanced Handbook. But reading those pages and comparing them with the Intermediate Handbook page 9, got me confused a bit for the following reasons:
    -In the Intermediate Handbook page 9 a potmeter is mentioned of 1W.
    -In the Advanced Handbook page 16 a potmeter is mentioned of 25W, replacing the 12-Ohm 10W resistor(s).
    Since up to this point I’m still working with my potmeter* from the Intermediate Handbook without any problems, I assume the 12-Ohms resistors didn’t need to be 10W, and neither is there a reason for using a 25W potmeter if a 1W is sufficient? If correct, I assume that the 10W resistors / 25W potmeter are just what they had lying around when doing the Advanced Manual tests.
    I’m asking this since I was in doubt whether I will make a switch to completely bypass my potmeter, or use a low resistance fixed resistor (so I can toggle between this fixed resistor and the potmeter) and started to doubt the wattage of this fixed resistor because of the above mentioned.
    *my potmeter currently is a 200 Ohm, 2W, 3%, 10 turns.
    Many Thanks in advance,
    Best regards,
    Rodolphe
  • Gary Hammond
    Hi Rodolphe,
    I assume that putting a couple of 1N4007 in parallel would do the trick as well? Or is the 1N5408 so similar in characteristics to the1N4007 that they can be interchanged?
    The 1n5408 and 1n4008 are both common diodes rated at 1000 volts PIV (peak inverse volts), however the maximum foward current rating of the 1n4007 is only 1 amp as opposed to the 6 amp current rating of the 1n5408. Switching speeds and foward voltage drop are about the same for both. So two 1n4007 in parallel could safely handle up to 2 amps and two 1n5408 in parallel can safely handle up to 12 amps. I had both on hand and went for a little over kill.
    The Nexperia BZX79-B12,113 zener should work just fine. This is only used as a voltage reference and is rated the same as the 1n5242 in both wattage (500 mw) and zener current (20ma max, 10ma typical).
    Gary Hammond,
  • pearldragon
    Hi Gary,
    In the process of learning about the SG and its components I just watched some tutorials regarding diodes. Before that, I was under the illusion that as long as voltage/amperage rating where more or less the same you can interchange one diode with the other. But I learned that different diodes behave very different under certain circumstances, I have some questions regarding diodes which I hope you can help me with:
    A single 1N4007 will probably blow as the current will exceed it's one amp rating. I use two 1N5408 diodes twisted together in parallel, and they handle the current just fine.
    The D3 diode of the comparator circuit (12V zener, 1N5242) I could only find in packages of 250. So at the moment of ordering I looked for a diode with similar specs, available in smaller quantities and ordered this one:
    https://nl.rs-online.com/web/p/zener-diodes/0508163/
    spec sheet: https://docs.rs-online.com/13a2/0900766b80b4c56e.pdf
    I was wondering if you have any idea if I can replace the 1N5242 with the zener diode I bought without running into any trouble?
    Many thanks in advance,
    Rodolphe
  • pearldragon
    Hi Gary,
    Thanks for your answers and input.
    I think the idea was to get the least resistance in enough turns to still get a usable amount of voltage. There is a trade off somewhere between number of turns and total coil resistance. It depends on whether you're after more voltage or more current.
    I understand, I guess that will make the difference then if the majority of the LEDS are in series or parallel. Among the parts I ordered are some (proto)breadboards and a variable resistor, so will have to experiment a bit to see how to light up most LEDs with my config.
    Another approach is to utilize coil shorting, as in a magneto circuit where the breaker points are closed (shorted out) until the magnets are centered over the coil and then suddenly open up. That is something I want to try, but haven't gotten to yet.
    I don’t understand completely what you mean here. If you have a link to where this is explained I would be interested, otherwise don’t bother for now: too much basic stuff that I still need to get done with my SG. But once if that is all set and done will come back on this.
    I understand what you say about how you used coil #1 and #2. What you did by putting one of those coils under the main coil, using more energy that is otherwise wasted, is very interesting. I assume this energy could also be used as input for another trigger winding of another SG (or make use of it in another way).
    I also discovered that I can parallel the DC outputs from both coils to charge a small battery
    Then I assume you could have also hooked up more LEDs in parallel instead of charging the battery in parallel? Or is that not true/incorrect?
    Best regards,
    Rodolphe
    P.S. In the meantime I’m working on my comparator circuit. Frame parts is done, now need to solder all the (small) components).
Name:	building comparator.png
  • Gary Hammond
    Hi Rodolphe,
    One of the things I was wondering about is why they used AWG16 in the handbook: for the little amperage that goes through the circuit, even AWG26 would suffice… (maybe it was just what they had lying around).
    Another approach is to utilize coil shorting, as in a magneto circuit where the breaker points are closed (shorted out) until the magnets are centered over the coil and then suddenly open up. That is something I want to try, but haven't gotten to yet. (Too many other experiments.)
    In the thread previously mentioned*, post #244, you say that you have 2 generator coils:
    Coil 1: as described per advanced handbook (10 twisted pieces AWG16 wire, connected in series, total length +/-305m)
    Coil 2: AWG23, single wound wire, +/-4026 turns.
    Both yielding more or less the same result.
    To clarify a little further, coil #2 was wound first and used as a generator coil on a different SSG. It didn't produce much output using a bridge rectifier. It would only power two or three LEDs and wouldn't produce enough energy to power the switching circuit either. That machine was triggered by a hall switch and ran maybe 250 RPM.
    When I modified my better SSG to replicate Peter's set up (Gary's "complete advanced" SSG build), I made coil#1 and added it like Peter showed. Then I decided to try mounting coil#2 upside down under the main power coil that runs the SSG. By doing this, I was able to inductively couple it and recover some energy that is normally wasted into the atmosphere without producing any measurable drag or reduction in charging! This coil, operating in this manner, will light the same number of LEDs (42) as coil #1 does. It uses the same voltage doubling arrangement as coil #1 and is totally dependent on the main power coil. (When the main power coil isn't triggering, coil #2 has no output.) It varies in output with speed also, but not as greatly as coil #1 does.
    I also discovered that I can parallel the DC outputs from both coils to charge a small battery as shown in this video. https://www.youtube.com/watch?v=R8hne9qVCww
    One other thing to note is that the two coils have different shaped wave forms as shown on the o-scope. The generator coil (coil #1) has the wave form I illustrated in my drawing of the voltage doubling circuit with a sharp positive voltage followed by a sharp negative voltage. And coil #2 has the same form form as the main power coil of an H-wave with a sharp voltage spike at transistor shut off. Neither coil has the normal sine wave form of AC power from the power company. That's another reason I didn't use a full wave bridge rectifier.
    Gary Hammond,
  • pearldragon
    Hi Gary,
    Thanks for your answers. This helps a lot!
    That schematic you mentioned in post #11: very clever! Thanks for uploading the sketch of the schematic.
    So I started experimenting by adding LEDs in series with various resistors and checking voltage drop across each LED and the resistor.
    I was planning to do some experimenting as well, starting with a potmeter rather than a fixed resistor.
    The coil wire
    My coil will be wound probably Monday (maybe Tuesday). At the moment I specified it at AWG16, +/-305 meter, which brings the nr of windings on the core that I use to +/-1125. If I contact the company Monday morning ,I might still be able to change the wire/turns, but if your tests showed not a significant difference, I’ll just leave it as is.
    RPM
    At 300 + RPM they are pretty bright, but get dimmer as the speed decreases. to 200 RPM where they eventually go out.
    Theoretically speaking (in the sense that also my gen coil circuit goes out below 200rpm too), that would mean that this circuit would only light up on my SG if I operate it in the single pulse area / the second gear area. Although I guess if the generator coil still produced voltage (but lower) at lower RPMs, I could remove some LEDs and have it still light up in the double pulsing area I guess.
    *http://www.energyscienceforum.com/fo...?t=399&page=22
    Best regards,
    Rodolphe
