Inside this FREE Solar Secrets eBook, you'll find...
- The biggest MYTH about Solar Panel Efficiency!
- Why MPPT (Maximum Power Point Tracking) Solar Charge Controllers will kill your batteries.
- The ONE type of Solar Panel the industry doesn't want you to know about.
- The KEY to rebuilding the batteries to like-new condition on every single charge!
- Getting more to your batteries from your panels than has ever been thought possible.
- And much more inside...
Get Your Information Now!
Click me now: Solar Secrets
My response was based on the specifications you posted. If the panels work, my guess is that the "operating voltage" ratings are quite conservative. If you look at the spec sheets for the 24 volt Tesla Solar Tracker 5s, the Open Circuit Voltage (Voc) rating is 42 volts. Both panels you list have this rating or higher, so maybe that is the better gauge of how well they will work with the Solar Tracker. Choosing between the two, I would pick the first one.
