  • Aaron Murakami
    I had posted this video much earlier on my original channel that YouTube banned without explanation. This is on my Energetic Forum channel that I haven't used in years. This was my indisputable proof that everyone claiming the plasma effect came from the inverter was false. I charge the cap with rectified ac output to 160 volts, remove it completely from the inverter output and then attach it to the primary of the ignition coil and we get plasma with the diodes connected from primary + directly to the top of the ignition coil hv output.
    Then Peter came up with the 555 relay circuit to help me automate that connect to power > disconnect/isolate > connect to ignition coil > repeat. If you put a diode to the top of the ignition coil primary and you have a distributor cap, if the plasma even happens, you're going to get it not only at the plugs but between the rotor in the distributor cap and the terminals for each plug, which will wear then down quicker. That is another reason for just bypassing everything and putting the cap through diodes directly to the tops of the plugs.
  • Aaron Murakami
    Originally posted by theplummer View Post
    Yes I've bought your ignition secrets package, as well as scoured all the other stuff available that isn't in the package. I see where there are experiments done with just attaching from the positive to the coil, through the diode, then to the coil wire and it worked there. That's what I've done, in the interest of expediency at the dyno, becuase I was only there as a courtesy guest for a friends valuable dyno time. I didn't want to eat up half his day trying to get my stuff working.
    I'm still curious why when the ignition is on, the MSD is not charging the coil, but it starts and runs on the engine. If there is no power at the orange coil wire, how can there be any cap power to transmit to the plugs. Also, apparently I was scavenging too much power from the cap, to charge the coil when it did trigger to the coil, that the coil would not charge enough to get any spark to the plugs, as it would not start, nor would the timing light pick up any spark to #1 plug.
    I see many tests that show the system running normally first, then adding the plasma ignition... Is it possible that the engine must also be operational, before adding the plasma... If that's the case, this is going to make my future experimentation much more difficult in changing fuel compositions and mixture ratios.
    I'm sure the MSD 6AL and your street fighter are using the same schematics, the only difference is going to be in the quality of components used, therefore, I wonder why the orange positive wire to the coil isn't getting any signal. Have you experienced such a delimma? This is on a system using the violet/green trigger wire to a MSD distributor.
    The Datsun video answers your speculation. It shows you that the engine does not have to be running first in order to then switch on the plasma. You can start the car with plasma - otherwise, it's not as practical. I connect the diodes and then start the car right up in the video. What people are doing is running the engine with normal cap discharge ignition then switching on plasma simply to show the difference - not because it needs to be running first.
    Another engine starting right up with the diode connected:
    I don't think the difference between the Street Fire and 6AL is quality of parts. The main difference is that it has a more robust charger to charge a cap that has about 35% more joules of potential energy than the one in the in the Street Fire. 6AL is 135mj and Street Fire is about 89mj. 6AL just a much stronger unit.
    If you have the 6AL connected and the orange wire is connected to the + of the primary of the ignition coil, there obviously is power there because you say so yourself that it starts and runs the engine. If there was no cap charging and discharging (positive of cap connecting to + of primary with orange wire), it would not start and run the engine.
    How are you scavenging too much power from the cap? There is a sequence to the events and it is impossible to take too much from the cap that would prevent it from starting or running the engine. Why? Because the cap discharges to the primary of the ignition coil FIRST. SECOND, the cap will only discharge through the diode and over the gap IF and ONLY IF it gets a spark. If there is no spark, the potential in the cap just sits there because there is no place for it to go. The gap is just an open circuit to the cap until there is a spark. The ignition coil will only take the bare minimum needed to make spark strong enough to conduct the cap over it so in that sense, it is self regulated so that you always get most of the cap to go over the gap automatically.
    Please elaborate on this: "Also, apparently I was scavenging too much power from the cap, to charge the coil when it did trigger to the coil, that the coil would not charge enough to get any spark to the plugs, as it would not start, nor would the timing light pick up any spark to #1 plug." if that happened when you connected the diodes and it wouldn't start, etc. my guess is you have the diodes pointing in the wrong direction. Look at the picture below. The diode in that direction only works if the HV output from the ignition coil is POSITIVE. If it is negative, you have to reverse that diode.
    The experiments showing a diode from primary + to the top of the HV output of the coil is just for a bench test demo or for a single spark plug engine such as my Champion Generator video above. I was the first ever to do that proving you can use the cap for both the primary power source and the LV source to jump the gap.
  • theplummer
    It does matter where you connect the diode. If you connect the diode from the coil to the top of a plug cable, any resistance in that line will eat up a lot of the potential from the capacitor. If you have too much resistance in the cable, you won't get any plasma at all. But if you connect it directly to the top of a plug, you eliminate all that resistance and wind up with as many joules as possible at the plug gap.
    MSD's statement about solid core wires is because they are expecting the entire cap to be discharged into the primary because that is all they know. We're not doing that so it doesn't matter what they think.
    Your belief that the whole cap has to discharge into the primary is not uncommon, but it is incorrect and this actually goes to the heart of my circuit, which is in the patent and is why my method of using the SAME CAPACITOR for BOTH the primary power source AND the low voltage high current source to jump the gap is the ONLY significant innovation in ignition history since the invention of the plasma jet ignition systems to begin with. It is also the most elegant in terms of being the simplest solution to create a plasma ignition since you do not need a separate cap charging circuit that charges a cap for the sole purpose of jumping the gap through a diode while still needing. You need a cap charging circuit for the plasma so the simplest solution is to purchase any off the shelf cdi or msd, add diodes and you're done. This obsoleted millions of dollars in patents filed by all the auto manufacturers, etc. over the last few decades who never understood that a single cap can be used for both.
    If you connect the 400 volt cap to the primary and only let 1% of that capacitor discharge into the primary, you are STILL hitting the primary with 400 volts - just with less current. You do NOT need the entire capacitor to discharge in order for the primary to see 400 volts, it is automatically already there whether you use 1% of the cap or 100% of the cap - the extra capacitance will not add any more voltage than is already there, the extra capacitance will just add more current and more current is not necessary to make a spark - voltage is comes first and once it breaks down the gap resistance, then current will flow and it takes almost nothing to ionize that gap so that it is conductive enough to have a low voltage cap discharge over it.
    As soon as the spark is made and the gap is ionized, 99% of whatever percentage of that cap will then discharge over the gap just fine. This is what makes my method unique - it flies in the face of what "everyone" thought was possible because countless people believe that the entire cap has to discharge to the primary including "experts" at NASA, JPL, Princeton, all the auto manufacturers and many plug manufacturers.
    I did this on the bench with a MSD 6AL about 10 years ago just to test it then I gave it back to the person who loaned it to me. It doesn't matter the model because it works the same on every single one. The exception is if there is a wasted spark ignition that uses a coil pack where the primary and secondary are isolated from each other and half the pack has high voltage positive and the other side is high voltage negative. Everyone said I couldn't make my plasma method work on that too, but I did it and even did a whole presentation on this to prove it.
    The only other consideration is the direction the diode is pointing and that is determined by the polarity of the HV output from the coil.
    Here is a MSD Street Fire MSD on a Datsun - Street Fire is MSD's budget line but doesn't matter, I made it work on their higher end units as well.
    I say 98 mj in the cap in that unit in the vid, but I believe it is 89.
    You will see that I'm using the same capacitor in the MSD to charge the primary of the ignition coil and it is simultaneously being used as the low voltage source that goes through a diode to the top of a plug.
    Did you purchase my Ignition Secrets package? I have a lot of videos in there showing a lot of bench tests where a single cap is used to charge the primary and is also used to jump the gap through the diode. Not sure why you would have any doubts - there is a ton of evidence in that package.
  • Aaron Murakami
    Originally posted by Richard
    Three capacitors in series will result in one third of the capacitance of one of the capacitors. Three 330pf capacitors in series will result in 110pf overall and theoretically three times the voltage rating of one capacitor but it is typically difficult to balance the applied voltage across the capacitors evenly.
    So theoretically if each capacitor is rated 330pf at one thousand volts then the three in series would be rated 110pf at three thousand volts.
    Therefore if one capacitor is too much of a capacitive load for a circuit, then two identical capacitors in series would be half the load.
    LOL, you're right - I was in a rush. My mistake.
    In any case, if there is too much capacitance, it will suck up all the discharge from the coil and there will be no spark. Peaking caps for ignition purposes need to have very small capacitance.
  • Aaron Murakami
    I don't mean to argue with you, but your explanations aren't making any sense.
    1. Yes I'm using peaking caps from the top of the plug to ground, and three in series is too much capacitance is sucking up all the spark. wouldn't the instant the points were broken, the stored electricity (however much it built up) be discharged back into the spark plug anyway? I'm only using 3 capacitors, just as every bit of information I've seen describes to do. So you are saying in a round about way, is for me to only use one cap instead of 3 in series?
    2. This really makes zero sense here. It doesn't matter where I connect the diode at, whether or not I connect it to the coil wire right out of the top of the coil, or if I go all the way to the plug, as the spark plug wire would also be back feeding the high current lower voltage and would get sucked up also. Unless I put another diode between the spark plug and the plug wire to isolate the plug wire from receiving the high current electricity, the wire will always have the same amount in it no matter where I make the connection to the system.
    I've studied the MSD installation manual, and determined that the orange wire to the coil will not be charged until the capacitor discharges at the moment of triggering by the distributor. This does make sense once I've thought about it, and it seems that a msd cannot be used in this manner, without another capacitor coming directly from the 12v source. It appears that when the msd signals the capacitor to discharge to the coil, the coil needs the 400 volts to charge and discharge the coil, and taking the energy away from the coil, is reducing what it needs to properly charge to make the spark jump at the plug.
    If I connect from the ignition switch positive 12v to a cap, then to the diode, then to the high voltage side of the coil (be it at the coil/distributor wire, or to each individual spark plug wire, that should charge the spark plug with the high current electricity. Now I realize that the high resistance of the plug wires may still soak up the high current electricity, and that's probably why you recommend low resistance spark plug wires. This is confusing because MSD says specifically NOT to use solid core spark plug wires as they will cause the MSD to malfunction.
    If you've actually used a MSD 6AL, do you have a video showing it actually working on a vehicle that I can watch?
