    I did. I've watched a number of times to try to figure out if it says 350' on top of the spool (I think so...)
    The pancake coils I was thinking of would be made of speaker wire or lamp cord, etc...lots more copper, and much thicker insulation than magnet wire...350' of coils can be compacted. heck, 1' of ethernet cable has 8' of wire in it...wire not too different from your magnet wire
    What it gets down to is just how much inductance is needed for the effect - pancake coils could be stacked as required until sufficient is my supposition, and one that needs testing to support or refute no doubt
    I used some wire on that spool so I'd guess there's at least 250 to 300 feet.
    For Tesla bifilar series winding method, I'd use a solenoid style wind rather than pancake for more inductance but you mind find something interesting with the added capacitance in the coil when charged. I didn't test that yet.
    • just to clarify - you put the spool between diode and primary?
        Did you see the presentations? I put it in there. Watch my plasma ignition and Grey tube/motor videos on Youtube. I lay the whole thing out.
        • It's time to re-shoot those videos: cameras/lighting and gimbal technologies have vastly improved, as has monitor resolution with end users/viewers and network delivery speeds. Further, I'd even suggest putting them on D-Tube if you have concerns over censorship and/or demonetization.
          • I just discovered that ferrocene mixed with polyisobutylene succinimide (PIBSI) is great for improving fuel economy (my bike showed about 5kmpl improvement, generator got an additional 40 minutes run time and my car got about 8kmpl improvement which is shocking, probably its because of multiple cylinders). With pure ferrocene I never experienced increased fuel economy, but it did improve acceleration.
            I made this concoction to improve knock index and improve cleaning properties of fuel. It turns out, it is really cost effective and more potent cleaner when compared to commercial products, and it really is extremely good at improving fuel economy. I am not saying this out of placebo effect, many of my relatives and friends also responded with comparable results (However, fuel injected engines are not yet tested). Maybe its due to the viscosity change in fuel that causes reduced fuel consumption in case of carbureted engines with this mix.
            Ferrocene Spark plug deposits are not forming with this mix as well.
            • Plasma ignitionFeatured snippet from the web
              The plasma ignition system is the structure involving direct ignition as is which can output both spark (by the high voltage) and microwave from a spark plug tip by mixing microwave of 1kw class 2.45GHz in the pathway of a high voltage supplied to the spark plug from the second coil of the ignition coil as shown in Fig.....
              https://www.denso-ten.com/business/t...f/Vol01-10.pdf
                you mix these in with your fuel in what proportion?
                • Originally posted by scilover View Post
                  I couldn't find a date of publication on the pdf. how current is it?
                  I've begun using a water vapour induction (rather than injection) system on my daily driver to great effect.
