Gander Revitalized Water
  • Gander Revitalized Water
    Does anybody know the construction details / concept of the Gander technology...... ring magnets nsns snsn nsns snsn nsns snsn nsns....is this the correct orientation???
    I think you meant Grander, from Johann Grander, inventor of this device. I wasn't able to find any details in past, only speculations and according to them the orientation should be as you have. I also heard that someone cut this open and found no magnets so it would suggest galvanic device but such idea doesn't make sense to me. Magnets do.
    Vtech
      thanks V tech
      they say they used high grade steel with tuned frequency... tuning of material can be done using technique of helpfulwaves.com but at what frequency
        In case of water I would consider solfeggio frequencies but I think they used something different here. Will try to find out.
        Meanwhile, an interesting subject study related to water, frequency and being energy efficient - http://****erson.gatech.edu/file/Wet....2012.0429.pdf
        Vtech
          Vtech
            Opposite poles attract and like poles repel. So that stack of Magnets would be repelling each other.
            That ()()()()()()() configuration would be a stack of seven Magnetic donut domains. Why Seven?
            Maybe the seven tilts of the Tetrahedron, which define the seven colours, the Seven Letter/shape Waveguides of
            harmonic nesting. Its a fundamental spin toggle of the minerals within the water that quite likely produces
            the energetic revitalisation affect.
            Yes it would produce a Grander spin density.
            BabaGlee
            "Stirwands" are Paramagnetic de-clumping of nested H2O suspension, devices.
            A return to basics.
