Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 102
Thread: Kapanadze generator ( kapagen)
  1. #81
    Post Filter, please elaborate on what a filter is!
    Quote Originally Posted by petio707 View Post
    Attachment 2240
    .In the original patent the inventor - Kapanadze - uses filters to lower the voltage even more and to make the frequency right - 50-60 HZ. I haven`t made the filters so far.
    Hi please can you eleborate on what filters are and how one would go about making one.
    Thank you
  2. #82
    Attachment 2240
    I built a successfull replication of Kapagen and I can explain to miself some of the princips of working of this Free Energy device. It is not a matter of RESONANCE as in a Tesla coil, but it is all about INDUCTION. I built it on a schematic called SSG ( spark gap generator). It works at less then 20 volts and produces hundreds of volts and a lot of amps. I start with a dimmer swich connected directly to the primary of a MOT ( Microwave oven transformer ). Then , a Microwave oven capacitor in series of the HV wire , a spark gap , a Kapa coil ( watch the assembly on youtube ) and a load of lamps.In my device I use the armature of the MOT as a mass and as a ground. When a load is applied to the device the magnetic fields in the Kapa coil wound CCW, CW, CCW oppose each other and thus lower the voltage before the load. The free energy is created in the secondary of the MOT in the formation of PLASMA. Through the spark gap the pulsed DC wave is transformed into a sine wave , then stepped down the voltage through the Kapa coil and some filters before it reaches the load. The last coil ( the thick one ) of the Kapa coil has to be at least 10 times thicker then the other ones, because it is the only way I have found so far to transform the HV into Low voltage and more amps.In the original patent the inventor - Kapanadze - uses filters to lower the voltage even more and to make the frequency right - 50-60 HZ. I haven`t made the filters so far. And again - to make a successfull model you have to use relatively small voltage for the MOT, transform it into HV to create a spark in the spark gap , and then, in some way, lower the voltage by an INDUCTION via thick wire from 2000 to 120-240 volts. The device produces more energy than it consumes and it won`t be hard to make it self running by adjusting the right voltages. It took me months of work to make it and countless hours to understand it but I am sure now I know how it works and it is not complex at all if you know how the electric currents travel through a wire at different voltages. The main thing to understand is : the electric current travels through the wire at lower voltages and around the wire at high voltages. And when it is at lower voltage it becomes an amperage current that can be utilised in any electric device. When high voltage is applied to a coil the current egnites a plasma field around the wire creating free energy , but to use it you have to step down the voltage making the current amperage current. Otherwise you end up with fancy sparks, arks and a question in your mind : How did Tesla make free energy he constantly talked about ? Well , he was a fan of tranformers and motors. He played with spark gaps and coils most of his life. Everyone can make a KAPAGEN. It is great fun and a bunch of burned bulbs and volt meters . Stay safe when working with high voltage.
    Hello my friend petio707, very impressed with your Kapgen work.
    In very near future (at present I am very behind another experiment on aymmetric motor build
    http://www.energeticforum.com/240261-post5504.html)
    I will put together your suggested apparatus, as I have at hand most of the components
    https://www.dropbox.com/s/3le6n79jdf...ig%20photo.jpg
    Left over of old Don Smith Tesla type of apparatus
    https://www.dropbox.com/s/tigzjwnf0t...20Build%20.jpg
    Warmest regards
    lightworker1
  3. #83
    Well wish all happy and prosperous new year.
    Last time we heard from Petio he could not get the money for a microwave transformer. He talked about it but and I would like to see more on his kapgen. He claimed that he was almost there, powering things for free.
    Let us know.
    Have you made any excess electricity or looped anything?
    Let me know.
    Thousands of experimenters are trying this.
    I have used car coils to get some strange lighting effects by powering the coils with an SG Oscillator circuit. High voltage stepped up and back down again searching for some resonant sync that gives more back.
    This guy did it to http://jnaudin.free.fr/kapagen/ at the very bottom we can see his measurements at 2X or more.
    His name is Jean Louis Naudin giving clear concise instructions. Here is the 100KWH model
    http://peswiki.com/index.php/Directory:Kapanadze_Free_Energy_Generator
    Don Smith is another man who is more than just a Youtube member, these guys have great labs and have done
    experimental of all kinds for decades. Here is his work http://www.free-energy-info.com/Smith.pdf
    Tesla did say that this transforming of energies using HV and spark gaps would bring huge increases in power production.
    Have you ever experienced any slight energy gains with your circuit?
    Mikey
    Hello @BroMikey
    The answer to if I have seen excess electricity? Not yet.
    This is the goal also in my present work on the other thread "Aysmmetric motors of ufopolitics". I must say it one great thread too.
    Again where many are working selflessly.
    http://www.energeticforum.com/renewa...tml#post247695
    I have been following J Naudin for over 15 years. One great guy.
    However this following guy also have, "Selfrunning free energy Kapanadze device." It appears that he is using some sort transistor switched stepped up device.
    Wam regards
    lightworker1
    http://www.youtube.com/watch?v=rbkvXoDfk7g
  4. #84
    I dropped my electric bill by 50 bucks a month by just putting tuning caps on my ac mains. now my house is in resonance going to my pole pig on the power pole. its all I can get without putting the pole pig into resonance with my house and blowing it up. I have another one on my panels at work that run my pumps when they are all running the panel pulls 75 amps per leg, turn on the caps and it drops to 50 per peg.... 35 amps from tuning the VARS.
    I find that VERY interesting, Tom. I wanted to find out more, but the board's search function wasn't very helpful; neither was Google. I realize this is off-topic for this thread, and so I am wondering if you could briefly point me to where I could learn more about this? Or, perhaps, start a thread in a more relevant section with some quick guidance?
  5. #85
    Quote Originally Posted by ErikN View Post
    I'm not interested in why a wire heats up...it's well known electrical theory. When you get the wire to cool, then you'll really have something!
    Erik
    Why it cools is also well know!!! only remains to be known in Academic Theory how to get it to that: whistle:
    if you really understood Why it cools than you as well understand why it heats which you seem to ignore... please don't ridicule any thing cause very minute detail in research is Gold precious!!!!!
    Hello!
    I\'m from Hungary so my English is bad. I replicate the KapaGen and it works well. But I want to use this energy in our house, so i have to convert this energy to 230v ac. How can i do it?
    I can\'t use a transformer because the output of kapagen is very unstable. Perhaps it\'s ac, but not sine ac. I want to convert it to dc and do acoutput with IGBT transistort, after this I going to use a transformer to reduced the voltage. It\'s my notion. Is it viable??
    Please help me, I don\'t have other idea.
    My e-mail adress: aszti911@freemail.hu
    Thank you very much.
  7. #87
    What is the output of the kapagen?
  8. #88
    I can't measured the output, it's very unstable, not sinus ac... and my 1000V graetz bridge was go wrong. So I think it's more higher than 1000V, perhaps 2kV.
    Now I bought 6kV diodes and it must be enough strong.
  9. #89
    Quote Originally Posted by Botster View Post
    sorry for the really late reply...
    http://electricsaver1200.com/blog/po...-power-saving/
    http://www.schneider-electric.co.uk/...n-modules.page
    http://www.eaton.com/Eaton/ProductsS...tion/index.htm
  10. #90
    until we can understand the output of the device we will not understand how to help and give some specifications of the components you may need. if it is A.C. a transformer to step the voltage up or down will work. if it is D.C. then a battery bank to store its energy is the next step, but how to interface the unit is still a mystery.
