Results 1 to 7 of 7
Thread: Mjl 21194 or Mjl 21193 transistors
    Junior Member Magnus M.'s Avatar
    Feb 2013
    Reykjavik,Iceland
    18
    Can i use mjl21193 transistors insted of mjl21194 transistors in my energizer ?
    Magnus, why would you wanna do that?
    John K
    Feb 2013
    Reykjavik,Iceland
    18
    Hi john
    I live in iceland ,and the mjl21194 are not availible ,but the 21193 transistors are.
    1,511
    That is even better for Radiant but has to be handled very carefully or will blow up much easily (MJL 21193 IS PNP and you will switch the POSITIVE SIDE OF THE CIRCUIT.)as compared to MJL21194..
    Feb 2013
    Reykjavik,Iceland
    18
    Thanks for your reply,i think i will just order the mjl21194 from Norway or Denmark.
    Best regards from Iceland
    Magnus M.
    Senior Member
    Adelaide, South Australia
    131
    Got a circuit diagram?
    Why would a supplier carry only the PNP and not the complementary NPN? If you do PNP, your trigger winding must be "grounded" to positive as well. Basically put a mirror facing vertical under the SG schematic, and what you see in the reflection is what you must build using the PNP.
    Just Enough Joules!
