Bedini bicycle wheel material
  • Bedini bicycle wheel material
    Hi guys. I'm just about to build my first Bedini SSG motor..........i just bought a bicycle wheel off of ebay. The guy said it was alloy but it turns out only the rim is alloy. The spokes are magnetic. Is this a major no no or will it be ok? Thanks
    Marine- John Bedini stated in one of the EFTV videos that the rim was the important part. The spokes can be ferrous, but the rim should be aluminum or some other non-ferrous material. You're good to go. I bought my bike wheel used from a local bicycle repair shop for $5. The bearings were the expensive part. I splurged and went with ceramics. $70 for those but I have not been sorry. The thing has a 18 min 27 second no coil free spin time. Make sure you thoroughly degrease the bearings and then lube them with some sort of PTFE type lube. Tri-flow works well, and lubrilon a.k.a. excelplus are even better if you can find it.
    Have fun,
    -Woody
      Thanks man!
        JB's new bike wheel kits have a steel rim.... when I was assembling it in the shop, he said the steel was fine, it helps the scalar south some..... I have run steel and alloy and nylon rims. I have seen SG machines rotored in an aluminum slug with slots cut out, and many other ways. seems spacing and magnet type are more important. Jb's 10 coil is nylon rimmed skyway bike wheel, single Sg is steel, 6 coil is aluminum......
          Cheers Tom.
          Is there a link on here to show how to properly space the magnets? I was going to use 50x25x10 rectangular neo ones. I think they were about 30kg pull each.
            Do not use neo magnets, ceramic C8 only. get the beginner SG book, it will answer all your questions. you space them 3 to 5 magnet widths apart. the book will save you a bunch of time.
            Tom
              Yeah i've been meaning to get the book for a while now. Cheers for the heads up.
                Hello again guys. I've had to put my build on hold up until now. I'm having a nightmare trying to find c8 grade 3 ferrite/ceramic magnets here in the UK.
                I've just gone and bought some of these as the guy on the phone said they are practically no different. Will these be ok? They are 50 x 25 x 10mm thick Y30BH Ferrite Magnet - 1.2kg Pull to be used on a 23" wheel. I have no idea what Y30BH means but the guy says you wont notice any difference?
                http://www.first4magnets.com/rectang...2kg-pull-p3531
                  anyone?...........
                    Welcome Marine,
                    Go to the Beginners Bedini Monopole forum, much more info there for you. The basic US magnet dimensions and specs for a ceramic magnet are 4.5 lbs (~2kg) pull and 1 7/8" x 7/8" x 3/8" (48mm x 22mm x9mm). These are on the TeslaG site.
                    Check out part # DM880 here: http://www.duramag.com/materials/cer...-magnet-sizes/ they do not mention the pull.
                      Marine,
                      those are close enough.... you want the magnet to completely cover the core, which those will. you will have to experiment with coil gap to find what is right.
                        Hi Yaro, thanks for the reply.
                        I'm ok on the sizes, it was more a question on the material of the magnet. They aren't c8 they are Y30BH. Is that ok?
                        I'll check out that forum as well. Thanks.
                          Hello Marine,
                          you are in the UK ?
                          Great.
                          I got my magnets from this supplier in Germany :
                          www.supermagnete.de
                          Check it out !
                            Sorry Tom C i didn't see your post. Thanks for clarifying that for me!
