Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: Tesla Switch
  1. #41
    Hawaii Big Island on the edge
    24
    Batteries 1 and 2 drop very slowly while battery 3 stays the same and battery 4 goes up.
    Splitting the negative terminals on battery 1 and battery 4 and using 1n4007 diodes to the load.
    Next I will try splitting the negatives on the negative side, batteries 3 and 4 with diodes to the load.
    https://www.youtube.com/watch?v=SAXVMaWSXS0
    https://www.youtube.com/watch?v=FfUKN9ABJ0U
    more data
    I have been splitting the neg. terminals between battery 1 and 4
    than I switch to neg terminals of battery 2 and 4; 1 goes down 2 goes up 3 goes up 4 goes down
    than I switch the load leads and battery 1 goes down 2goes down 3goes up 4 goes up
    so switching the leads to negative terminals around gets different battery charging results.
    also I have been running a load; small motor and light and other things to see what happens so a slow discharge is expected.
    I did notice when you use amp meter (don't leave it in after adjusting) on load and adjust the switch timing you can see a point where no current draws but the motor and light still run.
    another thing the leds don't need to be 12v. 12v leds take too much energy. The leds can change colors depending on where you power you load from.
    next I am going to run it with no load and see if the batteries will charge back up
    happiness and joy
  2. #42
    24
    Thanks John I'll Try this Happiness and joy Jeff
  3. #43
    1,510
    Here is John Bedini's version of the circuit using opto-couplers:
    Attachment 532
    ' Pulse Charging a Battery and driving other devices with a Pulse'
