10 Coiler Battery Swapper!
  • 10 Coiler Battery Swapper!
    'you cannot swap with the 10 coil without transforming the energy into the battery - cap pulser or something like that.'
    how is the group expected to swap the batteries and get no result? of course unless you use R-charger at the front end and asking that bank of battries to charge the primary...
    rgds,
    rgds,
    I expect that you will get no results except degrading batteries unless you transform the energy..... charge the front end however you want. solar panel wind or hydro free energy from the planet once the hardware is paid for.
    if you want to learn to swap batteries, do it with a single coil SG and the peripheral devices already available.
      I know all these (Solar panel, wind , hydro ) will not do what the R-charge does..
      and the peripheral devices do the same thing a sthe R-charge..
      The transformation of Energy that you are referering to is the Transformation into the Radiant which swapps between the Non-Radiant one...
      rgds,
