Page 88 of 122 FirstFirst ... 3878868788899098 ... LastLast
Results 871 to 880 of 1215
  1. #871
    Quote Originally Posted by Hellenic Vanagon View Post
    Now I know: 6A-7A current are, in fact, used by the primary, (although, at the secondary, the amperage is at mA):
    https://drive.google.com/file/d/1pbV...ew?usp=sharing
    LINK: http://dtec.net.au/Ignition%20Coil%2...alibration.htm
    Now does any one know what can happen, (to the ECU), connecting two ignition coils in, (primary & secondary), parallel, feeding them by the same triggering module, which is designed just for one coil?
    In the above, excellent, linked, article it is mentioned: " Primary voltage usually lies in the 300- 400V range and is electronically ‘clamped’ in most systems to prevent the switching device being damaged".
    So it seems that, usually, there is an overloading protection.
    But there are so many other aspects, f.ex.,
    #1 using two coils, are they operating cooler, important factor to their sensitive resistance vs temperature?
    #2 is their rising coefficient improved by halving(?) their operational stress?
    At least, this is claimed by the next article excerpt about the Jag's system:
    https://drive.google.com/file/d/1Cw0...ew?usp=sharing
    #3 is it better the auxiliary/main configuration or, if they are matched, at least, it is better to discharge through separate, parallel, paths?
    Indeed, Voltage and current are inversely proportional.
    That second link, explaining dwell, is wonderful. Thank you!
    It seems that a capacitor in parallel to (across) the ignition primary is an excellent idea in any application; sizing it correctly is the issue.
  2. #872
    enjoy smelling Ozone a littel of this gas is mood rejuvenating i must say
    Tesla is smiling.
    T.v. antenna unlike
    any other https://drive.google.com/file/d/1y9M...ew?usp=sharing
    floating valves not giving feedback https://drive.google.com/file/d/1ogq...ew?usp=sharing
    to each other.
    No missing signals
    from the air
    no blurred signals
    on the air.
    Tesla is smiling. (From there).
    Bips and bums
    and burning lights
    smokes and thunders
    and delights,
    currents, voltages
    through air,
    sparks and arcs
    but no despair.
    Yesterday a burning light
    flawlessly hovering at night
    a message carrying to the site:
    "Tesla is smiling" (From height).
    The Syncro Heresy
  3. #873
    In my case a capacitor in parallel is forbidden by the manufacturer, ("do not connect capacitor of any kind to the primary"), but there is no prediction about a second, parallel, coil.
  4. #874
    Tesla is smiling.
    T.v. antenna unlike
    to each other.
    No missing signals
    from the air
    no blurred signals
    on the air.
    Bips and bums
    and burning lights
    smokes and thunders
    and delights,
    currents, voltages
    through air,
    sparks and arcs
    but no despair.
    flawlessly hovering in night
    The Syncro Heresy
    A bit clairvoyant as well! Ozone smell and clairvoyance bear synchronicity!
    compare Electrolytic Ozone (produced at high-Current density) and that produced by High-Voltage Silent Electric Discharge(corona-discharge)
    @ Aaron your expert comments please...
    Best Regards,
  5. #875
    Yes, Both Parallel and Series Capacitor or both simultaneously (like i said in a Natural Lightning Discharge) can infuse Unpredictable power surges that can undoubtedly damage your scale of design in the coil/Switching etc..! question is.. how do you it at will ???
    when you use kittering coil application its Parallel capacitor with Parallel Resonance (connected continuously across the primary), while in CDI/Plasma it is Switched Capacitor with Series Resonance. The Manufacturers of coils say that for this reason..i feel.
    Its my sincere urge to all to experiment with Parallel and Series Resonant High-Voltage Coil see what you end up with..! Look how the nature does it even with out a 'coil' understand it. what the hell in a Lightning Discharge is playing the role of a Coil??? Triboelectricity(Frictional Electrostatics) is just not it!! ponder on these lines and you may end up with the holy grail of Tesla's Secret to Free Energy!!
  6. #876
    Another point: retarding the timing, as it is supposed with plasma, there is a sharp increase in consumption, according to the trip computer measurements. It has to be as close as possible to the pinging point for the less possible consumption.
  7. #877
    From my documents collection:
    Here is the reduction in the voltage can be done by a resistor, (R stamp), sparkplug:
    11313 volts, (with a 4960 Ω, conventional, resistor), vs 23.31(=nothing) volts!
  8. #878
    It seems that, finally, I found a way to post BIG images...
  9. #879
    Connecting my MSD?
    When you hook up the MSD/CDI, you are already getting a stronger spark at each plug - from coil, thru distributor directly to each plug.
    After the MSD/CDI is hooked up, then you add diodes. 4 of them.
    If you're coil isn't suitable for capacitive discharge, I'd recommend this one: https://www.amazon.com/gp/product/B0...SIN=B002Q363XM
    After getting the cdi/msd hooked up, post your results and then we can diagram the diodes to the top of the plugs. That will be super easy.
    Hello Aaron,
    Since I only have the stock 96 Tacoma distributor, do you have an idea of how to connect my MSD unit to the magnetic pickup? Would I disconnect all the original wires coming from the magnetic pickup inside the distributor and connect the MSD to it as if it were an MSD distributor? Will that work? Does it get any signal from the computer that I will be interrupting?
    Ron
  10. #880
    1,448
    I now have my Street Fire unit and am ready to do the final hookup!
    If you can fill me in on the rest of the hookup pointers I will greatly appreciate it!
    Happy 4th of july!
    Ron
    Have you hooked up the unit to your car and ran it with just the basic MSD ignition?
