Now I know: 6A-7A current are, in fact, used by the primary, (although, at the secondary, the amperage is at mA):
https://drive.google.com/file/d/1pbV...ew?usp=sharing
LINK:
http://dtec.net.au/Ignition%20Coil%2...alibration.htm
Now does any one know what can happen, (to the ECU), connecting two ignition coils in, (primary & secondary), parallel, feeding them by the same triggering module, which is designed just for one coil?
In the above, excellent, linked, article it is mentioned: " Primary voltage usually lies in the 300- 400V range and is electronically ‘clamped’ in most systems to prevent the switching device being damaged".
So it seems that, usually, there is an overloading protection.
But there are so many other aspects, f.ex.,
#1 using two coils, are they operating cooler, important factor to their sensitive resistance vs temperature?
#2 is their rising coefficient improved by halving(?) their operational stress?
At least, this is claimed by the next article excerpt about the Jag's system:
https://drive.google.com/file/d/1Cw0...ew?usp=sharing
#3 is it better the auxiliary/main configuration or, if they are matched, at least, it is better to discharge through separate, parallel, paths?
