Page 86 of 123 FirstFirst ... 3676848586878896 ... LastLast
Results 851 to 860 of 1224
  1. #851
    The plasma ignition accelerates the combustion process so the timing can be delayed a bit closer to TDC. In some experiments both cars and generators, some have have even found the best results firing after TDC. My generator is infinitely adjustable and I just adjust it by sound and am not sure what the timing is set at. I never modified the timing on my Subaru EJ25 engine. On my Datsun 620 pickup, I haven't got that far yet.
    As a note, the o2 sensor circuit should never be used without a combustion enhancer like "hho" or the plasma ignition because it will be too lean. It is the EFIE circuit - electronic fuel injection enhancer or enhancement. I built one with a LED circuit controller for a 1991 Honda Civic DX long time ago - it measures the voltage from the o2 sensor and drops it before sending the signal to the fuel computer so it pumps less fuel. I was using only fuel line magnets and fuel additives. When I got the car, it was doing 32 MPG. By the time i was done, I was able to get 43 MPG on the HWY AND in the city!
    On my Honda and Subaru, I never modified the air flow sensors.
    For my Datsun, I'm getting a full range of jets so I can get as lean as possible while still dropping the engine temp - yet to be determined what that is. I have a EGT - exhaust gas temp gauge and there is a blocked off port on the exhaust manifold for an old air pump inlet I believe so I'll try to put it in there.
    For clarity's sake, when you say accelerate, I think you mean "causes the ignition event to happen sooner in the 720 degree rotation of the 4-stroke combustion cycle," correct? it also delivers the ignition energy FASTER, for a much better sense of accuracy; plasma can reliably be aimed to hit the proverbial bullseye much more easily, I think.
    EFIE circuit - yes, any combustion enhancement; Plasma ignition, HHO/Brown's Gas, Gadgetman Groove...you also have to be mindful that you may need to modify a MAP signal to ECU as well, if your vehicle has one.
    Leaning an engine - this youtube video, while long and focused at aviation, has some great insight (or did for me). https://youtu.be/h3bATVXMHQg
  2. #852
    Thank you.
  3. #853
    1,456
    No, the electro-chemistry involved in the actual combustion process is sped up.
    The plasma doesn't cause the ignition even to happen sooner, it will happen whenever the timing tells the ignition to fire but because the combustion chemistry happens faster, the timing can be delayed closer to TDC.
    Yes, the plasma causes the energy to be delivered faster, which compresses the same energy in time meaning the power of the ignition is cranked up through the roof.
  4. #854
    Street Fire
    Hi Ron,
    As you mentioned in the emails there isn't a MSD type unit specific to the 2RZFE. However, many units like the budget MSD model Street Fire is universal and can be used on most 4, 6 or 8 cylinder engines as can the other MSD units. Very few are engine specific but are for a general type of engine. Dis-2 or 4 or whatever I used in my Subaru are for distributorless, the Street Fire can be used for points or electronic ignition that use a autotransformer coil with normal primary inputs and a high voltage output, etc.
    The cap you mention isn't needed because if you can hook up a CDI/MSD to your engine, the cap in that unit gets discharged into the primary of your ignition coil so you have a corresponding stepup in the high voltage output that increases. So instead of 12 volts going to the primary, you'll have 400-500 volts to the primary from a low capacitance capacitor. The Street Fire unit has 89 milijoules per discharge I believe and you can find up to the 135-150 range or so.
    Can you post a picture of your ignition coil and the cables that connect to the plugs?
    I now have my Street Fire unit and am ready to do the final hookup!
    If you can fill me in on the rest of the hookup pointers I will greatly appreciate it!
    Happy 4th of july!
    Ron
  5. #855
    so "combustion happens faster at closer to TDC because the charge is more compressed" is how I'm understanding it...and yeah, the results would be remarkable.
  6. #856
    Quote Originally Posted by Hellenic Vanagon View Post
    Thank you.
    most welcome!
  7. #857
    Aaron,
    'Plasma-Chemistry' will be a better term to it..
  8. #858
    I'm curious Aaron what kind of magnets were you using, how were they configured on the fuel line, what strength were they and what kind of additive did you use? Because I have tried all of those things and never got any gains that were worth speaking of?? I was also using an EFIE circuit, do you remember your circuit voltage settings for the offset the EFIE was putting in the computer?
    Ron
  9. #859
    Ron
    Ron - the EFIE needs to be adjusted to your application; that said, if you poke around on the Eagle Research website, you'll find that there is a good range to start your adjusting. Did you watch George's video? https://youtu.be/zGXxXM_lzAQ
  10. #860
    My next step is to connect two ignition coils in, primary, parallel or anti-parallel scheme.
    It looks promising but it poses an overload on the triggering unit which may be, I am afraid, fatal, (for the unit).
    My first experiments, on the bench, give impressive results.
    An '80s solution:
    https://drive.google.com/file/d/1Ge1...ew?usp=sharing
    For the moment, works perfectly, covering the area above the 4000 rpm.
    To see the thumbnail better, click the link, (google drive).
    Last edited by Hellenic Vanagon; 07-03-2018 at 11:44 PM. Reason: Better thumbnail vision info.
