Page 70 of 121 FirstFirst ... 2060686970717280120 ... LastLast
Results 691 to 700 of 1203
  1. #691
    What do you think of these videos?
    Thank
    YouTube : Simple Plasma Ignition - my actual installation
    YouTube :Simple Plasma Ignition - Result After 3 Months
    YouTube : Simple Plasma Ignition - Capacitance Effect
  2. #692
    1,528
    [QUOTE=ahGM;27895]What do you think of these videos?
    Thank
    YouTube : Simple Plasma Ignition - Capacitance Effect[/QUOTE
    Videoattachment missing please....
  3. #693
    Hi
    Links :
    https://www.youtube.com/watch?v=IRJUCLUp6-k
    https://www.youtube.com/watch?v=olCKGti0t8E
    https://www.youtube.com/watch?v=qQFx1jmgiic
    Thank you
  4. #694
    1,528
    Quote Originally Posted by ahGM View Post
    Hi
    Links :
    Thank you
    Hey,
    Please buy Ignition Secrets of Aaron Murakami....that's true Plasma Ignition to date.
  5. #695
    1,437
    Hi
    Links :
    Thank you
    Nice demo on the peaking capacitors. They definitely work and are time tested. I like your 3rd video to show the difference with adding more capacitance. Peaking caps are definitely a low budge and low tech to get significant results above stock.
    Have you experimented with the plasma jet ignition method?
    Here's an example:
  6. #696
    Hi
    I really appreciate what you've done for me(Faraday88 and Aaron Murakami)
    This video was fantastic. That's a great Invented
    I don't experimented with the plasma jet ignition method . but i want to learn
    1- Is plasma jet possible with standard spark plug? example: Bendix Autolite 94 spark plug
    2- How much volt is a plasma jet spark?
    3- Is it possible that this high voltage will break the piston?
    Kind regards,
    ahGM
    Thank you .
  7. #697
    1,528
    Hi
    Kind regards,
    ahGM
    Thank you .
    Hey,
    Just check if the spark plug you bought does not have a resistor in line...you need to remove it for Plasma Ignition method..
    Aaron will chime in to comment more...
  8. #698
    1,437
    @ahGM,
    1 - yes, as long as it is a NON-RESISTOR spark plug. If you use non-resistor plugs with your capacitors in parallel (peaking caps) you should get better results too.
    2 - the voltage will be the same as any capacitive discharge ignition system.
    3 - it is not possible with voltage.
    The plasma ignition method causes a low voltage high current capacitor to jump a gap when it normally will not. And it does it at a decreased resistance meaning the cap discharges very fast so the power gain is enormous. You are getting a huge power impulse. If the capacitor is too big that jumps the gap, it could possibly damage the valves, etc. but if you only use a capacitor in a common off-the-shelf CDI or MSD, then you will not have those problems.
    All details are in http://ignitionsecrets.com package but you could see the basic setup on my Datsun pickup video.
  9. #699
    Hi
    Thank you Dear Aaron Murakami and Faraday88
    It was very nice of you to help me.
  10. #700
    I was wondering if someone could help me out with creating better spark with a Typical battery points and condenser/capacitor ignition system on a old lawn tractor
    I do not want to put a msd box on it because that system would probably cost me more than the tractor lol. Could I use a 20kv diode like Peter did in the video on page 1 of this thread. Thank you Jeremiah
