Page 69 of 121 FirstFirst ... 1959676869707179119 ... LastLast
Results 681 to 690 of 1203
  1. #681
    Hi Aaron, are u using a normal rectifier diode or a schottsky diode..? I've done some reading on diodes while designing a new shell for my "injector spark plug" and saw there is a lot of different diodes for different use's and features. Schottsky seems to be the best way to go..? Probably won't really matter but was just wondering. I Googled and read Wikipedia's Schottsky diode explanation and saw that the diode brings quite alot to the table in this circuit..!
    Thanks...
    Enige iemand kan enige iets doen...as hy regtig wil.../Any one can do anything...if he realy want to...
  2. #682
    1,437
    Quote Originally Posted by morné View Post
    Thanks...
    Hi, it is a normal high voltage diode.
    I've been using these - 1 for each spark plug: PRHVP2A-20
    You can find them cheaper on Ebay but have to wait longer.
  3. #683
    1,528
    Thanks...
    Schottky diodes are suitable for low voltage /high-current Applications...
    these are not available in High-Voltage range due to the fabrication limitation of its characteristics (point contact diode).
    hope that answers the difference..
  4. #684
    Thanks Aaron, that link does not ship to SA but I'll have a look on ebay.
    Thanks Faraday88, did not notice that info on the link I red..!
    Any updates on anyones plasma conversions yet.?
    Thanks again...!
  5. #685
    1,528
    Thanks again...!
    You are right the link does'nt cater to India as well!
  6. #686
    Earlier in this thread Aaron shared a video comparing Grey tube with his ignition system and in that video he added a inductor to the circuit after the spark plug. He said doing this made the plasma turn green. Has anyone tried adding a inductor onto an actual internal combustion engine to see its effect on combustion? Also second question I have is I am going to be using msd 8224 coils, they are waste spark coils but my engine has 2 plugs per cylinder so I will use one waste spark coil per cylinder firing both plugs on combustion. Will an inductor still have the same effect with 2 spark plugs. I plan to try to use copper spark plug indexing washers attached to a HV wire so that the current can flow between plugs without having to go through the engine.
    Third question, could an inductor be used as a electromagnet around the fuel rail to ionize the fuel? Would it be strong enough for that or would it work better to use a step up transformer as the inductor then use that to power an Electromagnet. I was thinking build the inductor around the fuel rail either as a hollow core inductor or around a Ferromagnetic tube that the fuel rail can go through. Either way would also have to figure out how to shield outside of it to avoid any emf from messing with anything else. I don't know alot about ionization but if that could be done could it be done so that the fuel has the opposite polarity of the plasma spark? And would that be beneficial?
  7. #687
    1,528
    Quote Originally Posted by carlmartin87 View Post
    Why does this site need moderator to approve before posting?
    EDIT :
    This posted so I will paste previous attempted post in this one.
    I can answer to your third part of the question.. the idea of boosting the calofrific value of a given fuel by Electromagnetic Excitation is possible 'Negentrophically'.
    Indeed, if you rasie the Energy Level of a given fuel from its ground state under Resonant Conditions,the resulting Fuel is in an excited phase and thats possible to any fuel (fossil) and is what Stan Meyer did to further raise the Energy Level of the HHO gas from the liquid state to the Gaseous state and then Plasma state but in Negentrophic mode..(The ionization mechanism involes the Asymmetrical regauging of the dipoles to re-direct the electrons in the powering mode in an associated Resistor element and Energy Mode in the assocaited polarized Fuel bulk) he called this as the Hydrogen fracturing process and the device was named Hydrogen Gas gun. or Electron extraction circuit.)
  8. #688
    1,437
    I don't know if there is any benefit to the inductor in series with the spark for ignition purposes. Personally, I would not do that because there is no evidence there is a benefit but there is plenty of evidence that without it increases the thermal efficiency.
    Again, with the coil packs, I would not use the inductors.
    Yes, both permanent magnets and electromagnets can allow more BTUs from the same fuel as long as the correct relationship between the magnetic field and direction of the fluid flowing through it is used.
    Some of my original experiments were to use the magnetic field to help launch the plasma from the plug, but those were crude experiments.
    What you're leaning towards with opposite polarity is to charge the fuel with one and charge the air with the opposite. That's the idea some of our products here: http://magnetizerproducts.com/products.php#autogas fuel is one and air is the opposite.
  9. #689
    Smile
    I am not smart enough to fully understand what you are saying what does Negentrophic and dipole mean?
    Would an Electromagnet be more effective than a fixed magnet?
    I was only thinking of adding the inductor into the circuit to get further use from the Energy being used, like using it to power Electromagnets. But if the difference in the plasma has not been tested on a engine it's probably not a good idea to try it atleast not without small scale testing.
    Were your experiments to launch the plasma successful and what would be the benefit of doing that?
    How would you ionize the intake air? I have looked up electric air ionizers but didn't fully understand how they worked enough to think of how to incorporate it into the engines intake?
  10. #690
    Quick reply I can post but click go advanced and needs to be approved by a moderater.
    Can't see what you type in quick reply window on my phone. Atleast edit and pasting it in seems to work.
    Also is two plugs firing plasma at the same time in the same cylinder dangerous to the engine?
