Water and fuel dont mix.
But if you use soap it wil. It works best with injection systems.
Use a t in the fuelrail as close to the injectors as possible.
Source the water fuel and soap seperate and mix them just before the fuel rail.
1%soap , 24%water , 75%fuel ,
Use little pumps that can be frequention modulated for the mixing. Little electronic device for the percentages.
And your plasma spark to make some extra steam.
The biggest bonus is emission. This can save the air we breathe. But your president will call you a terrorist
I'm looking for a CDI module that only fires once per trigger (no multiple spark discharge). Does anyone know of a few sources for these?
I don't know of any that are commercially available nowadays, but I built one years ago (1968?) from a schematic in an electronics magazine. It was fairly easy to build and did run the engine ok (67' Mustang GT with 320HP 390 engine), but caused the tach to register about 5500 RPM at Idle. So I never used it. I still have most of it lying around some where, and I think I may still have the magazine with the schematic in it.
If I can find the magazine, I'll send you the name and issue #. I could also send you a copy of the schematic if you wish.
Hi Aaron
Found it! It was the February 1967 issue of Radio - Electronics magazine pages 32 thru 34. Volume XXXVIII No. 2
I also found a link to it on the internet where you can access the entire magazine including the article and schematic! http://www.americanradiohistory.com/...cs-1967-02.pdf
Hello all; just a minor update.
Working on the project more now that winter has set in and not much to do outside and the holidays have passed.
I did send in the ignition module for a warranty repair but they sent it back indicating nothing wrong with it...
I reinstalled it and seems to be working fine so don't know what the previous failure might have been. *shrugs*
I went ahead and produced a short update video and I'm pretty much ready to try starting the engine soon.
Aaron; you are correct in that a carburetor with fully adjustable mixture would very useful but these are pretty rare except in aviation applications.
Last summer I did manage to locate an old carburetor for a two cylinder Onan engine that I used on an antique tractor repair.
See: http://www.furaffinity.net/view/17732264/
This is a Tillotson DY11A with adjustable idle and main jets.
I was lucky to find a good one on Ebay for about $150
This offer has been available for many months now-
http://www.ebay.com/itm/Genuine-Till...-/301409989701
But the asking price is pretty high... Although not really that high for what is essentially a brand new (old stock) carburetor.
If I am successful in actually getting the engine to fire on water mist or fog, then I will pursue working with different jet sizes to see if I can get the stock carb to work with water.
With regards to single spark CDI; I am not sure why you might want this so I am curious what the reasoning might be.
And I imagine it might be possible to modify the street fire to do this. Just need somebody to study and figure out the modification(s).
Kindest regards;
Hey Aaron.
A quick search on the net did reveal these offers of tiny CDI systems made for model engines like they use for model aircraft.
Some of which appear to be an open architecture and not epoxy encapsulated making it easy to modify or study the circuit.
http://www.cncengines.com/ic.html
I do believe that unless "multi spark" is specified, just about any CDI is probably single spark such as this offer of a cheap CDI for a scooter-
http://www.dbelectrical.com/p-8551-n...c-scooter.aspx
But I don't think any of these simple systems utilize a voltage boost inverter like the street fire system has.
Hope that helps.
Kindest regards;
Aaron, you ststed in the above that your plasma ignition works on modern cars. I assume that you mean cars that don't have the regular ignition coil that you use in the video.
I have your book Ignition Secrets and as best I can tell only the old style coil is used. I would like very much to be able to use thePlasma Ignition on my car, but I am lost because I have no coil to work with, other than the one inside the distributor. My car is a 1997 Acura CL 3L V6.
I will be unable to use the plasma ignition until I get some more information. I hope someone will be willing to tell me how to go about using this technology. And a parts list would be most helpful.
I may also have some helpful information that would allow water to be more useable as a fuel. I have never seen this
information mentioned anywhere. Thank you for your help. UseNoFuel
