Page 5 of 113 FirstFirst ... 345671555105 ... LastLast
Results 41 to 50 of 1129
  1. #41
    1,398
    Rikard,
    Please post a full clear diagram of the second setup. It works every time with that Street Fire module.
  2. #42
    The diagram is as follows:
    plasma setup revision 2 | Flickr - Photo Sharing!
    I called MSD last night to double check the HV polarity and it's positive for all my coils in both set ups.
  3. #43
    1,398
    Quote Originally Posted by energyrikard View Post
    Your plug diagram looks a bit odd. Are all the striped lines the threads of the plug or the ceramic insulator?
    Other than that, assuming that the ignition coil is really HV + output, and your diodes are good, I think it should work fine.
    It would be identical to what I did but I used a different coil that has HV - output so the diode(s) were in the SAME place, just reversed.
    If you remove the diode, does it work as a normal CDI if you manually trigger it?
    Let me know the answers to the 2 bolded questions first and lets go from there.
  4. #44
    1,398
    These are some diodes I'll be testing when I can free up some time. I plan to use these on my Subaru with wasted spark ignition so my diodes have to be opposite polarity from each other since half the coil is + and the other half is -.
    They're 2A 30kv high frequency ham radio didoes. You can get them from Ebay for about $25 a piece delivered.
    They have different ones with different amp ratings and voltages.
    I think the voltage is fine and 2 amps should be more than enough. I use the 6A100's normally because that is 6 amps at whatever voltage the strings is and it is VERY INEXPENSIVE.
    If you want to try these, search ebay for HV diode ham - but buy at your own risk. I'm not making any claims since I haven't tested mine.
    They have threads on each ends for screwing a connector to so that's handy. They're potted so it may be made of multiple smaller ones, not sure, but if they work good, can be a time saver.
  5. #45
    Question HV wire for diode strings
    Hi everyone my first post here...
    Rikard and Aaron, one detail I caught someplace in the Ignition Secrets info, was using HV wire in construction of the diode string. I haven't even got my diodes yet, but I found an online auction and bought 10 ft. of HV wire rated at 30 KV. Tinned stranded copper wire w/ white silicone insulation, 7/32" O D, rated 30KV. Cost about 20 bucks.
    I'm not an electronics guy, I bought this wire for diode strings, thinking to err on side of caution.
    I don't know just how important this detail is...?
    Here's a couple pics, in case this may help.
    I finished installing my MSD Streetfire 5520 CDI in my '85 Subaru yesterday, works great. Torquemaster plugs to follow, then zero resist. plug wires/diode strings...
    I want to thank Aaron and the other great folks here for all they have and are doing. Important stuff, seems to me!
    Subadude
  6. #46
    My answers are:
    1. The striped lines are the threads, and that's where the ground is. I'm not grounding in the white insulator...
    2. When I have the diode connected with diode arrow pointing towards HV, there are no sparks at all. When I remove the diode strings, there are CDI sparks. When I reverse the diode string so the diodes are arrowing towards coil+ then there are CDI sparks again.
  7. #47
    Quote Originally Posted by subadude View Post
    Subadude
    Subadude, have you managed to get any plasma from your system?
    I'm using 16AWG wires, if you think I need HV wires, I'll get them ASAP.
    One thing I have seen is that the setup I'm using is creating _A LOT_ of EMI/RFI noise. I'm using the MSD spark tester to generate the triggering for the 5520 and there's so much noise that the LED display goes haywire. I called MSD and they confirmed that EMI noise screws up the display... I have it in a tubular shielding but it's not earthed or shielded very well. Not that I care so much about noise now, as I just want to get the phenomenon...
  8. #48
    Subadude
    Subadude.....
    Where did you get the wire....it's not so easy to find.
    Carl
  9. #49
    Hi Carl,
    I just ordered 20ft off of ebay. Search:
    High voltage wire
    You can sort it on "highest price first". You will see wire ranging from 10kV to 100kV. My coils go up to 45kV so I picked up the 50kV sort.
    I don't think the wire will make any difference in my application, but since I have tried almost everything... Why not?
    Also picked up a 2a30kV as well to try with...
  10. #50
    Quote Originally Posted by hh1341 View Post
    Subadude.....
    Carl
    Hi Carl found it on ebay. I just searched for HV wire, and browsed results. good luck! subadude
