Page 112 of 120 FirstFirst ... 1262102110111112113114 ... LastLast
Results 1,111 to 1,120 of 1196
  1. #1111
  2. #1112
    Well I just stopped at Summit yesterday and picked up a new coil like Gary is using a Msd Blaster 8222 but I haven’t gotten a chance to hook it up yet. The reason for the different coil was after talking to Msd they said that the Street Fire 5520 works best with there coil that’s .5 ohms or more, and they said that the Pertronix III maybe heating up and cause the misfire so I figured I would just give it a try to actually see if it could possibly be the problem. I now Aaron is using the same Pertronix III coil I have without problems. The only other thing I’m going to do is try to separate the wires incase they might be putting out some kind of electrical interference between themselves.
  3. #1113
    Hi Jeremiah,
    Are we still talking about your 14HP Kohler engine, or are you now talking about this on your car instead?
    I was wondering if someone could help me out with creating better spark with a Typical battery points and condenser/capacitor ignition system on a old lawn tractor
    I do not want to put a msd box on it because that system would probably cost me more than the tractor lol. Could I use a 20kv diode like Peter did in the video on page 1 of this thread. Thank you Jeremiah
    Its a 14hp Kohler
  4. #1114
  5. #1115
    Hi Jeremiah,
    Just curious, is this a modified K321? Pulling tractor? Cub Cadet?
    Besides the ignition, what other mods have you done to the engine? Is the Pertronix Ignitor 1 made specifically for this engine, or did you have to adapt a different one and somehow connect it to the crankshaft? Would love to see a photo of what you're working with.
    As for the misfire problem would you describe it as an intermittent total loss of ignition or rather as random, sporadic, events only lasting one or two revolutions at a time? If your plug was badly worn in a short time, you may have gone too wide with the plug gap? What heat range plug are you using and is it the correct reach? Is it a projected tip plug?
    What kind of plug wire are you using? If you said before, I don't remember what you said.
  6. #1116
    My Plasma mkIII Cordon Rouge is here:http://www.vwsyncro.eu/p/blog-page_34.html
    4 ampere 380v pure current.
    The 3 and the 4 channel diode banks cannot handle the huge 4(+) m.m. gap of my kinked 90 surface discharge spark plugs, since the voltage is raised above their limit, (although they are working well with the standard NGK 1.3 m.m. gap).
    I am working to overcome the above problem, as well as, problems with the sync(h)ronization of the two plasma units, problems with EMI/RFI emissions, (since the tries to ground the cable shielding must not include the tv cables physical aluminum shield, the arc is so strong that is grounded through the shield!).
    Extra shields, extra units, (6 amperes is possible with the existing setup), absolutely precise advance adjustment on the road, (by the insight and the ear), decisions about the correct height of the spark plug ignition height point, protection against overheating if the 555 transistors malfunction, protection against water, decisions, decisions, decisions...
    The difference between the initial 2A current vs the 4A current of the new Double Plasma, mkIII, Cordon Rouge
    module, is not theoretical, at all, it is very present and, hopefully, it will be seen in my next video.
    The Syncro Heresy
  7. #1117
    Gary, I’m running a magnet crank trigger pickup off the shaft end with no other engine mods. Also I’m using a Granatelli wire and a Pertronix III .3 ohm coil with a plug gap of .035 or .040 which is standard for these plugs.
  8. #1118
    everything works fine except when you connect the MSD box...MSD suggests the Pertronix coil has too low of an impedence on the primary:
    sounds to me like you need to hack the MSD to swap out the cap, and my gut instinct says you'll have to go higher on volts and lower on Farads than stock to balance things out...or rather than swapping it out, adding another of the same in series with the original. big help for me was to look at the wiki page on Farads - the energy equivalencies...if you're a math guy.
  9. #1119
    Pulse Jet and proper plasma ignition. Plasma ignition works!
    We have been experimenting with Aaron's plasma ignition system with our new pulse jet engine coupled with tesla valves used in the correct way. The plasma ignition makes a huge difference in the ability to burn whatever gas or fuel we use. Testing before and after using the plasma ignition shows an extreme difference in the intensity of the explosions, the explosions are faster and louder. The interesting thing is when we add just the right amount of water to the mixture, the power is again intensified leading us to believe there is a large amount of energy coming from the combustion of the water after it is split into hydrogen and oxygen.
    Here is a link to the pulse jet.
    https://www.youtube.com/watch?v=BaUfAs3MADo
  10. #1120
    what happened to the exchanger coil in the "high power" portion of the video?
    (the coils work better when the flows oppose each other - it looked like you had yours reversed from this)
