Page 107 of 120 FirstFirst ... 75797105106107108109117 ... LastLast
Results 1,061 to 1,070 of 1196
  1. #1061
  2. #1062
    I use a MSD 8222 High Vibration Blaster Coil with mine and it works great! It has only .7 ohms resistance. Here's the link. https://www.jegs.com/i/MSD-Ignition/121/8222/10002/-1
  3. #1063
    Pertronix claims you need a 3.0 ohm coil for 4 cylinders or less. Place I bought it from said the same thing but there not using it for what we’re doing either. I also have a Pertronix Ignitor I magnetic pickup sensor also. I ran the coil and sensor and it’s working fine. Next step is to hook up msd street fire and diode up. Again my main concern would be either to much resistance and not achieving plasma or burning something up.
  4. #1064
    1,420
    The most common coil I have used is the Flame Thrower III https://www.amazon.com/gp/product/B0...SIN=B002Q363XM
    3 ohms itself should be an issue. I can make the plasma with a few hundred ohms in the line. However, the coil you have I do not believe is suitable for capacitive discharge but the Flame Thrower III is. See the specs below:
    Pertronix Flame Thrower III coils are an ultra low resistance (0.32 ohms) 45,000-volt coil. Thet were engineered to charge to peak current typically 30-70% faster the other coils. This means maximum spark energy is sustained to higher engine RPM. Flame Thrower III coils are compatible with both the Ignitor II and Ignitor III electronics. They are available in both chrome and black finish for that "stock look".
    Pertronix Flame-Thrower III Coils Features: 45,000 volts
    Ultra Low 0.32 primary resistance
    Compatible with Ignitor II and III systems as well as most capacitive discharge boxes.
    Charges to peak current typically 30-70% faster than other coils.
    Rapid charge time means maximum spark energy is sustained to higher engine RPM
    Legal in all 50 states and Canada. (C.A.R.B. E.O. #D-57-10)
    If your budget allows it, this coil is a BEAST: https://www.amazon.com/gp/product/B0...SIN=B0006302P4
    That's what I got for my high voltage N machine experiments. I had it on my Datsun pickup for a while, but I didn't want $200 sitting there looking pretty so I put a Flame Thrower III on it. As a side note, this MSD coil would be incredible for Tesla experiments, getting it into resonance would shoot some serious fire.
    It only has 0.016 ohms on the primary!!!
    Brand MSD
    Color Red
    Emission Code 3
    Inductance .250 mH
    Maximum Voltage 45,000 Volts
    Peak Current 2 Amps
    Primary Resistance .016 OHMs
    Product Type Coil
    Secondary Resistance 30 OHMs
    Spark duration 150 uS
    Turns Ratio 70:1
    Type Drag Race / Long Duration Use
    Weight 3.75 lbs.
    Part Number 8261
  5. #1065
    Thanks Aaron and Gary, I already picked up a Flamethrower III now so I should be in good shape. On another note how well have the diodes (Prhv2a-20) you’ve been using holding up? I bought a few extras just incase of problems.
  6. #1066
    1,420
    Personally, I've never blown one of those diodes up and they are rock solid.
  7. #1067
    The only time I had one fail was when I accidentally forgot to hook up the ground lead to the spark plug threaded end on my test rig. It caused large arcs between the coil tower and coil primary connection.
    Never had one fail on the actual engine installation.
  8. #1068
  9. #1069
  10. #1070
    has anyone input their coil's etc specs into this calculator?http://bgsoflex.com/igncoil.htmljust in case it might help to fine tune anything...
