Bedini RPX Sideband Generator
ONLY 150 118 90 2 SEATS AVAILABLE! - 2018 ENERGY CONFERENCE
Monero XMR
Page 105 of 106 FirstFirst ... 55595103104105106 LastLast
Results 1,041 to 1,050 of 1053
Thread: Plasma Ignition | Plasma Jet Ignition
  1. #1041
    Thanks Aaron, I did a little more reading on the Digital Hp and found another interesting capability of this unit. And that would be that it has 2 power output settings and on low output is 145mj and high is 187mj, still higher than the Street Fire though. In your experience what brand plugs hold up the best with plasma?
  2. #1042
    Join Date
    Sep 2012
    Location
    Bangaluru, Karnataka, India
    Posts
    1,470
    Quote Originally Posted by Aaron Murakami View Post
    Yes, but for $45, that is a better deal for me. It would take well over 10 times that amount worth of my time to do it by hand. I guess it depends on where you are and what economy you're working with.
    Aaron,
    During my tenure at Honeywell I worked for an 'Ignitor' Project, and we custom made these HEI Spark coil, it was a CDI type of Ignition system and we had these miniature coils hand made with heavy insulation using a material (don't recollect the name) like teflon. including the wire jacket made of the same material.
  3. #1043
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,340
    Blog Entries
    1
    Quote Originally Posted by RB176 View Post
    That's a great option to have - still a bit hot on the low setting, but really depends on the plugs.
    I've used simple off the shelf non-resistor plugs.
    What I found that I still haven't had time to test are the iridium and/or paladium non-resistor plugs by WeaponX Performance - something like that. Easy to find online. About $15 per plug or so. They look the most promising but of course will not know unless they're actually tested.
  4. #1044
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,340
    Blog Entries
    1
    Aaron,
    What was the application for the ignitor? Was it for an oil burner, etc.?
    What is your opinion on custom making Coil On Plugs with a HV diode built into the potting compound to seal it all up? How would you go about it?
  5. #1045
    Join Date
    Sep 2012
    Location
    Posts
    1,470
    It was for a Aerospace Project not sure the end application but must be for a spontaneous combustion kind of Fuel im sure like the Petrol.
    Yes, Aaron some companies are already making integrated Plug on the Coil. I'm, keen to make a coil to try out what i said for your kind of Plasma Burst,Ido have a few ideas on exactly what you refereed about the HV diode integrated as well.
    each layer would be about 10-15 turns and several layers over each other, each layer epoxy insulated. (the old CRT EHT Coil)
    I would use several lower Voltage diode is series to the coil (Intermittently) and the encapsulate them as a ready to fire unit!
    howz that?
  6. #1046
    Hi RB176,
    .................................................. ..... In your experience what brand plugs hold up the best with plasma?
    I'm using NGK shunt gap plugs with the plasma ignition in my VW powered Bradley GT. So far, so good. They perform really well in the modified engine. The ignition module is an MSD A6 unit triggered by a hall sensor in the distributor.
    Gary Hammond,
  7. #1047
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,340
    Blog Entries
    1
    howz that?
    I worked with Arvind briefly who was involved with the other 2 out of 3 inventions in the plasma ignition patent. For a while, he had some company in China integrate the diode into the COPs. The company was flaky so we couldn't rely on the supplying us with product so I had to stop promoting them a long time ago.
    Yes, there are many COPs out there, even performance ones that don't cost very much. To retrofit a diode is out the question for the average experimenter.
    If there was a COP with at least an exposed connecting terminal to the top of the plug where an external diode can connect to the top of the plug, that would make it easy - no need to actually have the diode inside. If it was inside, I guess as long as the rating is high enough beyond what is needed so they will not blow out, then would be even easier. Would be nice to be able to turn them off and on, which would be possible with an external diode.
    COP plasma system is lacking because of the COP/diode issue not being easy for the average person. If I had them, I'd be able to put it on my 2006 Subaru Outback XT 5-speed - this turbo model has the coil on plugs so is a bit more complicated than the coil pack on my 98 Legacy.
  8. #1048
    I’ll be using the PRHVP2A-20 Single Phase High Voltage Rectifier Diode so with these diodes, so I’ll be putting the cathode side towards the plug. Is that correct? Coil + to —>|— towards plug?
  9. #1049
    Hi RB176,
    On my set up the diode (+) is toward the plug and the diode (-) is toward the coil primary that is marked (+) from the MSD box. It all depends on which polarity your coil is.
    If it doesn't work one way, just swap the leads on the diode. It isn't going to hurt anything if it's backwards. It just won't fire the plug at all if it's wrong. It just shorts out the plug gap if it's backwards.
    Gary Hammond,
  10. #1050
    Aaron, During my tenure at Honeywell I worked for an 'Ignitor' Project, and we custom made these HEI Spark coil, it was a CDI type of Ignition system and we had these miniature coils hand made with heavy insulation using a material (don't recollect the name) like teflon. including the wire jacket made of the same material.Rgds, Faraday88.
    kapton, perhaps? it's used for wiring harnesses in aviation applications.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
