Page 102 of 121 FirstFirst ... 25292100101102103104112 ... LastLast
Results 1,011 to 1,020 of 1207
  1. #1011
    Hi Rokan,
    Any ideas of how we can get this to work???
    Did you try the suggestions I listed in post 992 with additional capacitors and a Faraday shield to see if RFI is the problem?
  2. #1012
    Hi Rokan,
    Not yet, been sick
  3. #1013
    Originally with everything stock I tried the multiple capacitors to boost spark connected to the spark plug wire T which connects to the top of the plug and the other end going to ground and it barely ran with those?? Seems that when I connect anything to the spark plug wire to go to the top of the plug it just screws the whole sparking system up and starts mis-firing???
    yeah, that's not what I asked.
    I keep going back in my head to the video of Peter Lindemann at a conference demonstrating how by simply by adding a diode, the dynamic of how the circuit performs is altered rather dramatically, making the plasma event rather spectacular in comparison.
    There was no T-cable, no MSD box...power on, power off & spark, repeat; Simple and elegant.
    Have you stripped your ignition down to the basics to replicate that?
  4. #1014
    1,438
    That is my original innovation on the plasma jet ignitions. However, that is best for bench tests as the HV output goes to a single spark gap.
    In a car, if you do that, the the capacitor must discharge through the connection to the distributor and then through a cable to the plug - it can work, but the cables have to be near 0 ohms or it dissipates all that potential.
    It's also more bulletproof to have a dedicated diode to each plug.
  5. #1015
    Not sure what you mean about stripping it down to the basics any farther than what has already been done?
    The capacitor system of connections works great on my 1995 Honda Accord but kills the ignition on my 1996 Tacoma pickup. Like Aaron mentioned earlier, there must be some kind of problem with the igniter circuit in this pickup? I'll bet if I swapped everything over to my Honda (MSD, coil and diodes) that it would work like a charm on the Honda! So something is completely different in the ignition wiring on the pickup that isn't obvious for this type of conversion??
  6. #1016
    Bingo! That's what needs sorting out so you can apply the mod appropriately, right?
  7. #1017
    Of course bulletproof and reliable/repeatable are best, Aaron, but rokan is trying to get it to WORK first. Right now all that's been happening is throwing darts over shoulders hoping to hit a bullseye - rokan's not even sure if the dartboard is hung in the traditional manner. The design can be modified to suit the application, based on the specifics of the application...which nobody has for this vehicle at the moment.
  8. #1018
    1,438
    If you do it with a diode from + of coil directly to the top of the HV output, then you will cause a plasma discharge between the hv and each plug connection in the distributor cap as well as the plug.
  9. #1019
    Are you saying I should try 1 diode from the coil positive to the coil wire that goes to the cap?
  10. #1020
    1,438
    Not sure what you mean by coil wire that goes to the cap.
    The only thing that does make sense as far as how to hook up your system is in the diagram I posted.
    You said it wouldn't even run that way, which means that Nology doesn't know what hv polarity their coil actually outputs. If they did and the HV output is actually positive, then the diagram I posted showing the diode direction would be correct and it would work.
    I would recommend doing the diode test that Gary explained. You have to know if those diodes are good or not.
