Page 100 of 121 FirstFirst ... 50909899100101102110 ... LastLast
Results 991 to 1,000 of 1203
  1. #991
    Hi Ron,
    As you said, theoretically it should work!
    I still have a few questions though.
    #1 - Did you splice the negative coil wire from the igniter and MSD white wire together inside the distributor or outside of the distributor? (Where is the splice located?)
    #2 - Which MSD wire did you splice to the other coil wire coming from the igniter and where is this splice physically located?
    #3 - Do you still have a condenser fastened to the positive coil wire coming from the igniter that the other MSD wire is spliced to?
    I'm wondering about Radio Frequency Interference to either the igniter, or the MSD module, or between the two (or maybe even the magnetic pickup and computer and wiring). Fastening a wire to the T-junction may cause it to become an antenna with nothing else attached.
    #4 - Did you fasten the High Voltage Diode up to both the T-junction and coil positive at the same time to check for plasma? Or did you only try running the engine with the diode completely removed? (Wondering about RFI from an open antenna effect.)
  2. #992
    Hi Ron,
    #1 - At first I spliced to the negative coil wire inside the distributor and now I have it outside the distributor
    #2 - No other MSD wire is connected to the other coil wire but I did try connecting the small red wire to the positive wire of the coil and it ran the same
    #3 - No
    #4 - I did both, there was some VERY strong spark/plasma but it would only run 5 - 10 seconds before completely shutting off
    Somehow RFI must be the problem but it doesn't matter whether it is an open wire or closed with a diode??? How can it be soooo sensitive with only one wire and/or diode connected?
  3. #993
    Hi Ron,
    I'm about to run out of ideas, but thought of a few things you might want to try to see if RFI is really the culprit here.
    #1- Be sure all your connections are good and solid - no resistance. This includes all grounding connections.
    #2 - Install capacitors to all 12 volt positive connections of the MSD module, the igniter, and the computer to help filter out RFI. These need to be as close to each component as possible.
    #3 - Use shielded cable to hook up the diodes to both the coil and the T-junction and be sure to ground the shield.
    #4 - If none of this helps try putting a Faraday cage around the computer fabricated out of steel screen or hardware cloth.
  4. #994
    Hi Ron,
    Great ideas!
    #1 has been done
    #2 I will have to try that, any ideas that would be good for cap values? I am assuming polarized caps, right?
    #3 I used some tv cable and grounded the shield that surrounds the cable with no difference in performance (it still misses)
    #4 I will have to give that a try also
    Thank you for all of your great ideas!
  5. #995
    I still don't understand WHY when only one wire is attached to 1 T junction that goes to the top of 1 spark plug and the other end is attached to NOTHING WHY does it cause the engine to mis-fire so badly it won't run???
  6. #996
    Can the RF be that strong to completely disrupt the whole ignition circuit to completely mis-fire?
  7. #997
    Hi Ron,
    The longer the antenna is, the stronger the RFI signal is. If RFI is really the problem, you should be able to pick it up pretty loudly on a small portable radio held under the hood of the vehicle. And probably even on the vehicle's own radio. (And maybe even the neighbor's radio which the FCC won't like. )
    If instead something is shorting out, you should be able to see it after dark.
    I would use whatever value the original cap in your distributor is. Or you could use caps like were used on old points and condenser ignition systems. They also used to have caps on the vibrating voltage regulators and even on the brushes of the old DC generators. As best I can remember, these fell somewhere between .47uf and 3mf at from 25 volts to 150 volts.
  8. #998
    1,434
    Ron, what is the exact part # of your ignition coil? Nology got back to me and they can confirm a few things.
  9. #999
    I think it is the PFC-M70, it's been a LONG time since I bought it?? Pretty sure that is it.
    Yep, double checked it and it is the M70.
  10. #1000
    Did you have a chance to speak with Nology yet?
    Thx,
    Ron
