Page 1 of 93 1231151 ... LastLast
Results 1 to 10 of 929
    1,264
    Thumbs up Plasma Ignition | Plasma Jet Ignition
    I'm starting this thread to talk about Plasma Ignition.
    I have Ignition Secrets by Aaron Murakami | Plasma Ignition available and it doesn't include technical support for people's experiments. I do however, help quite a few people out anyway, but from now on I'm only going to address any of that in this thread. So if anyone has questions, they have to read this entire thread first and then if the questions aren't answered, I can try to help out.
    The concept is simple - high voltage from coil jumps the gap and ionizes the gap and makes it conductive enough so that a lower voltage capacitor in parallel with the gap can discharge over the gap creating the plasma impulse.
    I'll post more later, but this is just to get things started.
    Answering these questions for all to see is a great idea......Thanks
    Here are my questions........
    My mosfet gets hot quite quickly.( Nte 2376 )
    I am using a 50/50 duty cycle on my 555 .( maybe the cause )
    I seem to be drawing about 4amps, to a standard auto coil with 12 volts. Does that sound about right
    Also I was wondering if you could explain the function of the several diodes in your 555 circuit and the very short off cycle.
    Yours
    Carl
    1,264
    Quote Originally Posted by hh1341 View Post
    Yours
    Carl
    Hi Carl,
    Thanks for bringing these questions here!
    I'd put the mosfet on a heat sink if you are having heat problems.
    Also, if this is just for a bench test, I'd reduce the duty cycle to the lowest possible to still get the effect.
    You can replace that 1k resistor with a variable one to adjust the on time. It will automatically change the off time.
    Are you using an off the shelf CDI or did you make your own cap charger? 48 watts being high or low would depend on that.
    The diodes on the 555, I really don't know. I used that 555 circuit for a long time for various projects because I can change the on and off times for serious pwm control.
    Thanks Arron,
    I may have not read all the info on the forum or missed a bit.
    This is what I was looking for........
    I think the setup to be applicable in a working application would need to have the cap switching done, solid state, and the voltage supplying the cap to be raised from available 12 volt to 120 by, say, a doubler array.
    One could use a step-up transformer, driven by a 555, but it's always good to keep the parts count down.
    What work has been done in this direction, who is doing it, can I join them?
    I need to get this on the road.
    Yours
    Carl
    thanks for getting this started. Just to be sure, this is what we are talking about right?
    I am very interested in how you are supplying the higher voltage at a steady rate on the vehicle itself. I was thinking of using a small 300W inverter. I am more interested in knowing what you have used that actually works.
    Thank you for sharing this mod.
    -KR
    Min2oly.....
    An inverter can and has been used to charge the cap.
    A DC voltage multiplier would be the bee's knees
    The mechanical relay is a weakness also.
    Looking for help on both these items .
    Carl
    BTW Arron, the package is well worth the 37 bucks.
    Carl
    1,264
    For my cap charger, I use this: MSD 5520 Street Fire Ignition with Rev Control : Amazon.com : Automotive
    This unit works perfect for my jet engine - triggered with the same 555 mosfet circuit you see in the book.
    The unit also works perfect for my gas generator - I put a threaded rod down the middle of the generator, put on a timing wheel with a magnet embedded in it it triggers a reed that turns on a transistor to connect the msd trigger wire to ground.
    ABS 4" end cap is bolted to the generator cover plate with the 2 bolts you see through the timing wheel. The reed switch and transistor setup is mounted to the inside of some ABS tubing that is cut about 4-5 inches long and that is pressed into the end cap. There is a bold coming through the top that I can screw down to lock it into place. Loosening the bolt, I can rotate the pipe inside the end cap to adjust the timing anywhere inside of 360 degrees so basically infinitely adjustable. Obviously, it will only need to be adjusted in a certain range.
    When the transistor switches, the white trigger wire from the MSD unit is connected to ground and that discharges it into the ignition coil.
    That is the Street Fire MSD unit with performance coil.
    For real applications, I wouldn't build my own cap charger - I'd just use an off the shelf MSD or CDI and connect the diode(s) accordingly.
    Some people get the off the shelf CDI/MSD's to work and some can't. I'm not sure why - there are too many variables. So far, I haven't been able to not get it to work with everything I've tried. Various MSD units, Street Fire (MSD's budget model), the old Tiger CDI, etc...
    @Patrick - the higher voltage is supplied directly by the ignition coil.
    1,264
    Carl
    Thanks Carl!
