Results 1 to 10 of 13
Thread: Bedini - You CANNOT, use a radiant charged battery in the SG circuit as the primary.
    For those interested in the question "Can a radiantly charged battery be used as the primary in the SG circuit?"
    Here is John himself stating that "No, you cannot use a radiantly charged battery as the primary in the SG circuit."
    http://www.youtube.com/watch?v=zbSW_4tHCeU
    Video is private, for Forum members only. Video is from Energy from the Vacuum Volume 6 INSIDE RADIANT ENERGY
    with John Bedini. This DVD is available at DVD List
    Thanks to Tom C. for his hard, tireless work on the Forum.
    Quote Originally Posted by longhorn View Post
    John Bedini - You cannot use a radiant charged battery in the SG circuit as the primary. - YouTube
    Thanks Longhorn for that find
    Senior Member
    Adelaide, South Australia
    131
    John Bedini,
    You mentioned a time period between swapping batteries.
    Would you mind specifying what that is? Is there a translation/negative energy aniahlation occurring within the battery?
    We would really appreciate your help in nailing down this issue!
    It makes a huge difference for those with limited resources.
    Thanks in advance
    This makes perfect sense now! The reason he says that you CAN take a battery from the back end and swap to primary in one clip, but says you CANNOT swap radiantly charged batteries to primary in another clip is this:
    OK, why CAN we swap batteries that have been capacitor dump charged, but not diode direct charged? Because the capacitor has REGAUGED the energy and we can use the battery as primary immediately. Well, the batteries being charged in line AFTER the first secondary battery, in parallel on the back end, have the energy REGAUGED BY THE FIRST SECONDARY BATTERY that is hooked up to the output of the unit. It is just like getting the energy through a capacitor! Batteries are just really slow capacitors, after all. The only battery that CANNOT be swapped to primary is the first battery in line on the output side that is directly hooked to the radiant output. So, obviously if you have only one battery on the output side then you cannot swap that battery from secondary to primary.
    As far as time between radiant charging and using as a primary, I have noticed that the radiant charging effects wear off of a battery that has been sitting for about 48 hours. Peter Lindemann also noted that the enhanced charging effects, such as quicker time to charge, only manifest when the battery was in CONTINUOUS use, in consecutive charge-discharge cycles. If the battery sat over the weekend then the effects would not manifest again until a number of cycles had been accomplished.
    Just for the sake of learning, I once took a couple of 1.3ah slabs and rotated them from primary to secondary in quick succession for as many cycles as I could without destroying them. The results were abysmal! It proved to me that YES the radiantly charged battery WILL POWER the SSG, however the results are a continuous degradation of the charge condition of both batteries, and is obviously NOT the way to operate the system.
    So, we can swap ALL the batteries on the secondary side ONLY IF the output is through a cap dump or other regauging method. If we use diode direct radiant output without a capacitor dump, then the only batteries that can be swapped are any batteries that are hooked up in parallel, in ADDITION to and after, the first battery on the output side.
    If this is not correct, then by all means please correct me!
    -Woody
    Quote Originally Posted by Woody View Post
    -Woody
    Woody,
    the batteries on the back end are in parallel, therefore they all see the same radiant, so the answer is unless all the batteries on the back end see the cap pulser circuit they cannot be run back to the front end.
    my 2 cents
    Senior Member
    131
    What is the time period required between radiant charge and the the point at which the battery has translated the charge to non radiant? At which time one may use it for the primary?
    I am confused!
    Woody,
    my 2 cents
    Ok, I can see that Tom. Thanks for the correction. With the cap dump, the energy goes in and pauses, then emerges into the the battery/batteries when dumped. With the parallel set up, the energy is going to all the batteries at once without stopping in one first.
    -Woody
    my own experience is that with larger batteries you need to be slower than the solid state likes to go. we want the battery to charge itself, "ring the bell twice" ring the coil, it rings the battery. if the battery is a drum how big of a stick do you need to make it resonate. if you hit it with a toothpick not much. this is why I like rotored SG's better. easier to ring the battery.
    First release: Possiblity of using SSG conditioned batteries for SSG input with mod
    Hi everybody on this thread. I have tried something which I will describe below which at first glances is allowing me to use my SSG conditioned/radiant charged batteries as the input
    for the SSG circuits (mind you the solid state variants). The draw down rate by experimentation is significantly lower than without the "mod".
    I basically have been experimenting with the "captret" and finally I found a combination that seems promising. I will need to conduct more cycles/runs to see if this is working as expected.
    The schematic/block diagram of the arrangement is shown below:
    Any thoughts guys?
    I never let my schooling get in the way of my education...
    Ok 3 runs later and the SSG conditioned battery is being cycled back and forth...has anyone else tried?
