Page 9 of 9 FirstFirst ... 789
Results 81 to 85 of 85
Thread: R-Charge Window Motor
  1. #81
    the full bipolar switch has been on johns website for years..... MOTOR DIAGRAMS AND LAB NOTES
  2. #82
    I've been working at scaling up my small neo window motor because it has impressive torque.
    I havn't had the desired success.
    Tried many larger setups but none have shown the effectiveness of the small one.
    Will continue.
    Bro d
  3. #83
    Will continue.
    Bro d
    Been working with my large WM and decided to go with one coil and condense it rather than spread it out to fill the type 2 rotor mag gaps. It now runs at 36v 100ma, no load. Decent torque when loaded and the amps go to 1.5 under heavy load.
    Have 1 x 1 x 4 C-8 Mags to make another WM and see how they do. Will report.
    bro d
  4. #84
    ren hi
    i have a window motor with 3 coils of 8 strands (wires) each . I am using 10ohm base resistors and i use one trigger wire . i want ot switch to hall effect but i am not familiar with the connections. i run the motor only with the the north magnets that is half the system. i will use one trigger wire and two transistors 21193,21194 and a 8599 and the 470ohm resistor on only one wire !!! what about the 10ohm resistors on the rest of the wires.
    i am confused with the connections
    thanks
  5. #85
    john hi
    can you help with the hall efect connections on my window motor. i have three coil of 8 strands each. what do i have to do!
    i will use the one wire from the one coil as trigger drive coil and add the transistors like the sequentual bipolar switch diagram. is that correct?
    i wont have to use my 10ohm base resistors? that i have on my coil?
    please reply
