Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Bedini self running method
    Anyone doing experiments with Peter L's and Aaron's recent vid and attachments?
    This is major to me.
    I tried it with a single coil bike wheel with poor results. (lawn %garden batts)
    Now I'm running 2 coils with all GC batts.
    Looks better.
    Setting up for 3 coils and the GC batts also. Can do up to 12 coils with frame.
    I want to push the comparator cap dump a little more.
    Bro d
    1,447
    When John accomplished this, he used a mechanical switch to dump the caps to the back battery bank. Mechanical switch has the lowest loss and for these massive cap dumps, is better than the comparator.
    Yes, you need a split-commutator when you break the power in between the pulses feeding the Energiser and the Motor function. JB did this in his 1984 single battery Motor-Energiser set-up. There are other
    refinments that can be done to this topology i shall not go into that here.
    1,447
    That is if you want to connect and disconnect the input side battery.
    For the method in Peter's presentation, John only had 2 brushes and a wheel with a brass bar that would make contact to dump the caps to the batteries. The front side was connected constantly.
    Aaron,
    Was Peter using a mechanical cap dump in the presentation?
    Bro d
    Hi Bro D,
    I'm not Aaron, but the answer to your question is no.
    What Peter demonstrated was a conventional radiant charge going into the charge battery in parallel with a large battery bank. No cap dump involved in the demo. The run battery and charge battery were switched back and forth at some interval. But whichever battery was in the charge position was always in parallel with the large bank of batteries which were always receiving a radiant charge.
    1,447
    Aaron,
    Bro d
    No, Gary is correct.
    The primary point was to show the battery swapping arrangement.
    Thank you Gary and Aaron.
    On another note, I noticed that a bike wheel in gen mode will run significantly faster when the charge bank is 24v and the run bank is 12v than when both are at 12v.
    I made an arduino controlled switching system with 14 spst relays to automate this while looking for self charging.
    pic attached
    When I used 11ns ultrafast diodes it improved but no self charging. This is with no cap dump.
    Maybe I can incorporate mechanical cap dump. Iv'e ordered everything and should be using it soon.
    I've automated the setup for this thread on paper but havn't tried it yet.
    PIC ATTACHED
    Great link for working out pulley sizes.
    https://www.blocklayer.com/pulley-belteng.aspx
    Keepin' on,
    bro d
    6 AND 8 RELAY COMBINED_PCB.pdf
    BEDINI SELF CHARGING COMP CAP DUMP.pdf
    Attached Files Attached Files
    1,447
    It looks like two pics are missing from your post that you referenced unless you mean the 2 diagram/schematics at the bottom.
    If you really want to replicate what John did, he used a Bedini-Cole bipolar switch as far as the circuit goes. I give details in the walk thru video I did of his original machine that did this.
    I'm building this setup now with two coils on a bike wheel.
    I'll try it tomorrow with SG ctts and 6 garden tractor batts.
    Pic attached.
    I've done many window motors with full Bedini/Cole cct but never multi coil / multi pwr winding setup and half Bedini/cole.
    self charging MECH COM_PCB.pdf
    thanks,
    bro d
