Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Currently working on Bedini Beginner
    I have purchased the Bedini Handout and am currently working on the beginner version.
    I followed all the instructions and bought almost all the same electrical components as stated in the handout.
    However, when I hooked my circuit up and connected the power, the NEON light lighted up and there was no current in the coil.
    Also, for the solenoid, I used a single iron rod instead of the multiple welding rods, is that okay?
    1,373
    Quote Originally Posted by bedinistarter View Post
    Just to have a little SG that just runs so you can learn the principles, a single iron rod is ok. Less efficient, but will work.
    Do you have the output connected to a battery to charge up? If not, the neon will light up.
    Please post some pics so we can see your setup.
    Okay, thank you for that information.
    I have an output battery, however it is a full battery, could that be the reason why?
    Also, what kind of board do you recommend a beginner to use. I am a currently using a breadboard, and it seems like it burns the plastic. Can I use a stripboard and solder the components onto it?
    I will post some pictures (Monday), when I get a chance to since it is not at my home with me.
    1,373
    Maybe you can place a dead battery on the back and see if the neons turn off.
    Breadboard - not likely it will burn the plastic. With some small setup if that is what you have, probably won't draw that much current but yet, solder the components, much better anyway with real connections.
    Hi, again,
    This might seem like a dumb question, but, I do not have any lead acid batteries to that need to be charged. Is there a way that I can discharge a sealed lead acid battery for the sake of this experiment? I tried hooking up a 12V 5AH sealed lead acid battery to 3 330 ohm resistors in parallel to try to discharge it, however the voltage will only decrease to 12.74V and stops there. Is there an explanation for this?
    Yes. The battery is not done discharging. What you are seeing is the discharge "curve". When you initially load a battery the voltage will drop quickly. Then it will level out in the mid 12 volt range and will drop slowly after that. What your seeing is when it levels out but still has plenty of current flowing. You have mistaken that for being discharged. If you keep that load on you will see that voltage continue to drop over time and eventually drop faster and faster when the battery reaches it's actual discharged state.
    Thank you so much for the information. 20190320_123920.jpg20190320_123955.jpg20190320_123955.jpg20190320_125456.jpg
    Attached are the figures of our circuitry. We hooked it up to the solenoid and power and charged battery but nothing seems to be working. Do you have any ideas on what might be wrong and what can we do to trouble shoot.
    Could it be due to the fact that we have yet to discharge the battery to about 10.5V?
    Thank you so much, we will continue discharging it and wait for it to go down.
    You would need to clarify what you mean by nothing is working. When power is applied nothing should happen. The circuit should basically just sit and wait. When you spin the wheel by hand it will induce a voltage into the coil. That voltage will flow in the trigger coil activating the transistors. If you spin the wheel and oscillations happen but it is not enough to keep the wheel spinning or to speed it up. Then you need to decrease the resistance on the base of the transistors.
    You have to find the point where the resistance is low enough to allow the trigger strand to activate the transistors, but just enough.
    The speed of the magnet passing the coil increases with rpm. That speed up increases the trigger voltage. So as the machine speeds up you will increase the resistance to bring the level back to "just enough" to trigger. This is why the efficiency goes up. The faster the wheel is going the less it draws....kind of.
