Results 31 to 34 of 34
Thread: Currently working on Bedini Beginner
  1. #31
    1,486
    Let's start from step 1. Run battery disconnected and charge battery disconneced.....wheel stationary.
    When you connect power to the "run" battery nothing should happen. If the neons light up at this point then the trigger is backwards. If nothing happens then it is as it should be.
    Once you have done that....if you spin the wheel you should see the neons light up when the magnet is passing the coils. "THIS CAN BURN OUT THE TRANSISTORS" IF DONE FOR LONG.
    If that happens but the machine does not continue then I would recommend testing the coil strands for each resistance to make sure they are the same. And maybe run the machine with one strand at a time untill you understand the operation.
    If you get to the point where the wheel is spinning under power then attach a charge battery. The charge battery absorbs the power that was lighting the neons. So when it is connected the neons should go out and the battery should begin to charge.
    Hi Bradly,
    What do you mean 'Trigger is backward' Forced oscillation mode you cannot run a rotored SG
  2. #32
    Faraday, I meant the non rotored version. If you take the coid from a machine with a rotor, stop the rotor and change the trigger wiring then the machine would oscillate without the magnets. But doesn't drive the wheel.
    In the video that bedinistarter posted it appears the neons light from the contact of the + power lead to the battery....unless the wheel was already spinning out of sight there would be nothing to trigger the neons to light at all at that moment unless the trigger was wired incorrectly for this setup and accidentally set up for forced oscillation mode.
  3. #33
    1,376
    Faraday, there are TWO basic oscillation methods for the SG circuit.
    The first is self oscillation - the circuit is 100% identical to the SG circuit but you crank up the base resistance to get it to oscillate - that is SELF OSCILLATION.
    The second is forced oscillation - The trigger wire is connected to the + of the battery so the circuit is changed just a bit - that is FORCED OSCILLATION.
  4. #34
    1,486
    Aaron,
    Thanks for chiming in. Yes I Fully agreed and i'm aware of this difference but with the premise of the what Bedinstarter stated the neo would not glow if the charge battery remains connected to the out put form the SG circuit in either conditions of the trigger. I have seen the neos glow whilst the out connected to the charge batteries only on the 30-coiler I'm not sure under what condition that happens. I'm baffled.
