Somender Singh has been awarded an US Patent for his discovery of how to gain more engine power and economy by utilizing a small groove cut into the squish area(s) of the typical Internal Combustion Engine (ICE). The Groove(s) allows gasses to expand and compress with a quality that has consistently improved fuel efficiency, lowered operating temperature, improved torque and max power as well as lowering idle speed significantly.
Just an intersting little modification I plan on doing on my car. 1966 chevy biscayne with 6 cylinder.
I am rebuilding a 6 cylinder 250 chevy engine which will have multiple technologies to improve mileage.
1 - most moving engine parts coated with tungsten disulfide.
2 - Singh groove machined into head.
3 - swirl grooves put inside intake manifold.
4 - PCV bypassing engine vacuum
5 - HHO fuel catalysing for shortened burn time.
6 - Plama Igniton
7 - vapor generator for improved mileage, vaporizes fuel at cold temp
8 - High compression pistons
9 - steam injection...water injection to replace part of fuel
10 - exhaust scavenger that goes on end of tail pipe
V-diode MPG Enhancer
11 - all the little tweaks and adjustments outlined in the Eagle research books on mileage improvement
DIY energy saving methods and devices
Like the carburetor enhancer, the hyco and the hyzor running off separate alternator to produce actual browns gas.
12 - Aerodynamic changes to car including blocking radiator, and using turbulator tape and vortex generators on various body edges
13 - Use of friction reducing lubricant additives in engine, transmission and rear end and axle bearings. With an eye toward the Diamond lube system.
14 - top cylinder oiler.
Goal is to have a large size car that gets 50 plus MPG
