Results 1 to 10 of 14
Thread: Two Bedini in parallel
    Hello everyone i am new in this forum, I am very excited about creating a free energy, but I have a question, I need to know if it's possible to plug two bedini systems in parallel as displayed in my schematic?, and if this configuration will make the systems work perpetually ? thank you.
    1,339
    Quote Originally Posted by Mineralman View Post
    Tom, Erik or John K. may know better, but you're on the right track.
    However, with batteries like you show, you are causing them to be charged and discharged simultaneously and they don't like that. It is best to either charge or discharge a battery but not both at the same time.
    John made some linear current amp circuits that took the recovery spikes from the SG output, put them to a cap and the circuit converted it to a steady DC current output. That output can be put to another SG to run it. The other SG recovery can be sent to one of those identical circuits, which in turn powers the first SG. So basically, just replace the batteries in your schematic with the linear amp circuits.
    It's been a while so I don't recall if there were batteries in parallel or what, but John and I did talk about this method, he said it was possible, but did not elaborate so maybe it was just an idea. In any case, that is my 2 cents.
    Thank you Mr Murakami for your answer, it's an honor for me, with your advice I will try to do some experimetations with the linear current amplifier, i found a schematic in another thread (http://www.energyscienceforum.com/showthread.php?t=3844 ) but if you have a better one thank you to release it.
    or maybe using an ignition coil or a tv hight voltage transformer or an lcd cfl transformer in reverse with a regulated output , i think it's the same principal alike the electric campagnies transformers because they can provide high amperage from a high voltage.
    1,471
    Hi Mineralman,
    Linear amplifier regulator was never released by Bedini..there is a mention of it in some thread here
    nothing more..just hoping to see it released some day in the public domain.
    ‘Mass is spatial density of Matter (Particle) and Temporal density of Space (Field)’.
    1,471
    Hi Mineralman,
    You can run a Back to back SG but not a SSG. what do you mean by a 'Load ' in your diagram? A battery is either running a SSG/SG or under a Charge by it. A load would essentially mean you are drawing or draining a battery to Power a Device.
    HI Faraday88,
    Sorry for the mistake, this is what i meant with this new schematic, it's a good news, so it's possible to made perpetual running
    by using a bedini sg , do you have a diagram of this configuration ?
    I found a video posted by Mr Murakami who shown mr bedini testing his linear amplifier and I am impressed by the charging speed.
    https://www.youtube.com/watch?v=be7_M_Xf5Iw&t=206s
    1,339
    Hi Mineralman,
    That's right - there have been replication attempts to do it just like John's but I don't believe John ever acknowledged that anyone got it right. Replications may work and that is what counts but in any case, John's particular circuit is proprietary.
    1,471
    HI Faraday88,
    Hi Mineralman,
    Yes that correction just makes sense now! nothing more to add its just back to back two SGs (or at least one SSG). but why would you need that kind of a set up?
    HI Faraday88,
    I am lazy so I want to take exces energy from both batteries and let the devices running, but I dont know if it's possible ? for exemple the phone's batteries can be charged and used in the same time , the same thing in the cars, so ? it's jus an idea.
