Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Two Bedini in parallel
    1,470
    Quote Originally Posted by Mineralman View Post
    HI Faraday88,
    I am lazy so I want to take exces energy from both batteries and let the devices running, but I dont know if it's possible ? for exemple the phone's batteries can be charged and used in the same time , the same thing in the cars, so ? it's jus an idea.
    Hi Mineralman,
    You cannot Charge and Discharge a battery at the same time. There is away out though but the sense to doing so changes its form. Does that tell you something? when you do that you do extend the period for effectively making use of the source Battery. You can discharge one battery at the same time charge another as you do in a SG system. its all about timing the pulses correct. Next,you can charge two batteries in two different ways at the same time discharge one that charges the above two. Many other iterations are possible.. it just takes tinkering and an understanding of how they work. Once you understand one and you are sure to master the rest!
    Hi Faraday88.
    Yes thank you, I understood that charging a battery during unloading was not possible. So I have to use the linear regulator if I can find a shematic similar to that of Mr. John Bedini or resign myself to use a single device.
    1,340
    Hi Faraday88.
    You can try that but I doubt it will work. It was a conversation I had with John but I never saw anyone do it.
    1,470
    Hi Faraday88.
    Hi Mineralman,
    You must first get a hold on how things work..next you can try out what they do, its only after this that you can be sure of the out come. The Linear Amp is a buffer between the SG and the battery, the battery is made use of with out consuming an iota of its stored Energy, this is as far as what I can speculate about the way it works!
