Results 1 to 5 of 5
Thread: Circuit for High Frequency Ultra-short Pulse Width DC Voltrlysis
    Circuit for High Frequency Ultra-short Pulse Width DC Voltrlysis. Where the decomposition of the water molecule is the result of HF Virtual break down in a resonant-step-charged capacitor. The resulting gas can be used as seen fit. The overall circuit will maintain it's efficiency even as applied current is increased. This cell system is designed to operate high efficiency, low power consumption and consolidate storage, purification, and pressurization requirements within one device. (This only only for the version of this device where special metal alloys are used at the negative electrode. Standard HHO gas can be created otherwise).
    Normal water would work in this setup, any water would work. Normal, sea, urine, rain, waste water, etc etc. This circuit prevents the Electron Double Layer and Electron Diffusion Layers from forming, which prevents brute-forcing and instead allows for Virtual breakdown
    For circuit estimations, the total current moving through the circuit will be maximum 350W generally 12V @1-6amps depending on how many "cells" are connected to the power supply.
    For device design, i'd go more for germanium diodes, a Static Induction Thyristor, and a standard FET fit for the current you plan on running through the circuit. For coil winding numbers i gave give you theoretical values for each coil that would suit as good starting points.
    Primary can have between 1-560 turns
    C2: (@P=560) 2,880 turns
    C1:3,000 turns
    S:3,020 turns.
    The voltage and circuit resonance can be changed based on the turn relationships, and the applied frequency. the Pulse Width is 300ns but the pulse frequency is between 2-25Khz up to 40+Khz. The circuit is experimental, so the values are completely open to be seen. I know what the theory says is an appropriate starting point, but who knows how the circuit will behave once built.
    What do you think?
    1,510
    Quote Originally Posted by tree Of Meraki View Post
    C1:3,000 turns
    S:3,020 turns.
    What do you think?
    Why do you have to have 2 switches in series (one thyristor) and the other (a MOSFET) as seen in your 1st schematic?
    The two switches are because the thyristor is necessary to carry high current loads into the coil primary, while the FET acts as a gate switch for application of a current frequency. By increasing the frequency that the FET is triggered the current applied to the coil increases. While the Thyristor simply carries the high current load and keeps the pulse width within 300nano-seconds
    1,510
    both the switches have to do the same thing whatever it be in synchronization when they are in Series -configuration.
    Yes, the FET controls the frequency the circuit operates at, the thyristor controls the amount of time that frequency is applied to the circuit. They are acting in synchronization.
