Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 145
    Member
    Oct 2017
    Sussex and Cornwall, England
    98
    Gary, When using an inductive strobe won't that only pick up on the HV pulses (coil outputs) rather than the coil current switch on event?
    Jules
    Hi Jules,
    Jules
    Yes that's correct and it would be at the shut off point when the magnetic coil collapses.
    Better yet, you can use a LED (with dropping resistor) in parallel with the gate of the FET to find both the turn on point and turn off point. It will stay on for exactly the same duration as the FET.
    Hi Gary,
    I have put together three drawings that simulate your 2 sensor setup and operation so I can figure out the best positions. It seems that my wide 'Trigger zone' will interfere with the clean cut off of sensor 1 at the appropriate moment so I have had to move it quite a lot further round to work. I hope the drawings and text on them are clear and I look forward to any thoughts.
    Jules
    What you show looks good, but your comment on "stage 3" has one incorrect statement regarding pulse width. Moving the sensors closer together will increase the pulse width. Moving them farther apart will decrease the pulse width.
    The leading sensor sets the turn off point and the trailing sensor sets the turn on point.
    Member
    Oct 2017
    98
    Hi Gary, I already have an LED (shown in my current circuit) that comes on when the Hall sensor triggers the transistor which then triggers the FET so I know at what point the current, in relation to the rotor/magnet position, should come on and this will be useful to find the right starting position for the sensor(s). Small adjustments after that will produce the optimum rotor speed for the lowest current drawn on the battery. I gathered that the value of the strobe is to see the ‘frozen’ position of the magnet when the coil collapses and which I presume will be somewhere near the middle of two cores.
    Ok re sensor spacing. Seems counterintuitive but if one works it through s l o w l y . . . . .
    Jules
    Member
    Oct 2017
    98
    Motoring at last
    Hi Gary and Yaro,
    I have it working! . I set the sensor on an adjustable slot so that it just turned off at TDC and, after a manual spin, it stayed running much to my delight. However, it was only about 200 rpm and best speed and lowest current (1.2 A) were achieved when the sensor was moved about 4mm towards the approaching magnet. I have yet to measure the rpm but I guess 450-500. I think that the few ms delay in the collapsing field meant that in the first position there was still too much pull from the temporary S pole.
    You can see a video of it running called 'Moving at last.mov' at: https://www.dropbox.com/sh/0y15dybr5...n2q6QhHCa?dl=0
    I have no idea yet what is happening to the pulses or if indeed the battery is charging. I mentioned the reverse polarity to the 'developer' but he has not observed anything like that in his case and his battery was charging well. I am also aware of the thoughts that discharging and charging at the same time is not the best way to operate the battery but I am keen to try and keep just the one battery. If necessary I could envisage a system where, for a few ms, the battery was only being discharged and then for the next few ms only being charged in a repeating cycle. No doubt the good old 555 chip could come in handy here.
    Re measuring the HV spikes, can I put my scope straight across the capacitor, in attached circuit, without any special attenuation and would increasing the capacitor to say 10,000 uF make any difference.
    I want to thank you and others in the forum for helping me get over these hurdles. I'm sure the next stage of discovery is only just beginning.
    Jules
    1,485
    True but it has been pointed out that this will work only at a specific rpm as it is time based. Ideally one wants a distance or angle based method so its independent of rotor speed.
    Jules
    Tweeking the mono-shot multivibrator should get you to the sweet spot that you are looking for your set up of the rotor..
    Faraday88
    Hi Jules,
    You can see a video of it running called 'Moving at last.mov' at: https://www.dropbox.com/sh/0y15dybr5...0last.MOV?dl=0
    Nice work.
    Heart of Vermont
    312
    Hello Jules,
    Very good to see your machine in operation, sweet! Congratulations to you on your persistence and focus. Now the real adventure begins! Keep us posted on your progress... BTW the .mov came across in the vertical position, not horizontal - it may be my player...
    Member
    Oct 2017
    98
    Thank you.
    I took it on an iphone in a normal way. Guess you had to watch it at 90 degrees!
    One technical query: Why don't Bedini type systems discharge the coil pulses straight into the battery rather than charge up a capacitor first and then discharging that? Wouldn't the result on the battery be the same? Agreed it is much easier to measure the voltage, and hence energy changes, of the capacitor but you need the additional switch to dump the charge. I expect that can be done electronically instead so that when the capacitor reaches a certain voltage value it discharges - like those water buckets in a playground; when they get full they tip over and empty the contents.
    The next stage of my journey is to see what's happening to the pulses . . . . . . .
    Jules
    Member
    Oct 2017
    98
    Revised Circuit
    Hi Gary,
    Yes I thought that the moment I wrote it.
    What I have come up with as a 'temporary' solution is to incorporate an isolating FET switch between the battery and the top of the coil. I don't know if the FET needs to have its Source at 0V but I'm sure you get my idea. Maybe this can be done better with a regular BPJ such as the BC549 I am using now or a power transistor but this is how I see it working with most of it what is working now. I refer you to the attached pen modified drawing 'Revised Circuit with Isolator' and the 'BEMF Generator V3 (Revised)'.
    When the Hall output pin goes low the collector on the tranny goes high which sends a high to both FETs. This allows current to flow from the battery with the additional FET acting as a one way valve in the battery + line. When the passing mag field switches off the sensor and both FETs are off then the now HV positive at the bottom of the coils can only flow to the battery through the three diodes.
    As I say, it might be simpler to use a regular power transistor (I have a spare T13009) but then it has to allow up to 4 amps through it.
    If this works then at least I can get the battery responding to the pulses and tackle the question of discharging and charging simultaneously to later.
    Regards,
    Jules
