Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 131 to 140 of 149
  1. #131
    Hello Jules,
    answers below
    Ok so the HV pulse from the generator's FET Drain (which reverses polarity and goes HV+) will connect directly to Pos of the Capture Cap. Where do the LM741 and the H11D1 get their power supply from?
    The collapsing current of the coils, when the supply is cut off, is a positive current that must flow to a negative terminal (of a capacitor, or of a battery).
    The 12V build then is suitable for a 36V setup and perhaps the lower threshold might be set at 40V and the upper at 48V but the lower in particular might need tinkering. Is it R10 that adjusts the lower and R13 the upper? I appreciate what hysteresis means in magnetic terms but not sure in this context (the amount of lag between the charge and discharge?) To clarify these thresholds visually is the attached right and the cap would normally discharge at the lower threshold?
    It seems to me that the roles of R10 and R13 are those. The simplest method of tuning I found was to tune the high and low thresholds by feeding the Cap Pulser with a DC lab supply and placing a voltmeter at the output of the mosfets. Place a resistive load at the output to drop the voltage when cutting the source.
    I specify that I have never tried to set the threshold higher than 48 V, but 23 / 24V.
    The term "hysteresis" can also be applied to a device that has a control of the level of the ignition voltage different from that of stop. This is the case, for example, of the thermostat of a refrigerator. In Cape Pulser, there is a hysteresis comparator.
    My small batteries are 7Ah each so three in series would happily be met with just one of those 15000uf caps?
    A single capacitor 15000uf would suffice for 3 X 7 Ah.
    cordially
    mml
  2. #132
    Senior Member
    Oct 2017
    Sussex and Cornwall, England
    103
    Hi mml,
    From your helpful information I have made my own attached drawing which is part of the build process for me. I hope it and the credits are right.
    I would need to feed the discharges via my battery swapper to direct them to the battery stack that is not driving the whole circuit at that moment.
    When I have finished testing the HV feed direct to the batteries I will start on this and let you know how it goes.
    Regards,
    Jules
    PS. The 12V zener diode IN5242 seems hard to come by in modest numbers so can I replace that with a BZX55-C12V as I have quite a few of those? The other diodes I can get fine.
    (In anticipation of what one earth will happen with Brexit )
  3. #133
    Hi Jules,
    I read a little more my notes and some post of the thread "Bedini Comparator Cap Dump". I found this information concerning a modification to be made between the 2 Cap Pulser 12V and 36V.
    For the 36V, D3 is a 15V zener diode;
    For 12V, D3 is a 12V zener diode.
    You can find the zener diode IN5242 at Farnell. I mainly buy my components at their home.
    Link: https://uk.farnell.com/on-semiconduc...5?st=1N5242BTR
    In your diagram, reverse the polarity of the white del (between terminal 6 of the LM741 and R1).
    cordially
    mml
  4. #134
    Senior Member
    Oct 2017
    103
    Thanks. If D3 needs to be a 15V Zener instead of 12V then perhaps I can just use the same as D2 (IN4744A)?
    Jules
  5. #135
    Senior Member
    Oct 2017
    103
    Hi mml,
    Having drawn up the circuit in readiness for the build I have come across an issue that seems to be relevant to the solid state design.
    When looking at how to arrange the negative side connection ports on the circuit board I realised that if I connect the capture capacitor to the main negative rail of the generator then I am effectively bypassing the cap dump circuit which switches the negative line back to the batteries in order to release the stored charge. I have shown this in the attached pic and where the cap dump circuit is traditionally connected to an independent coil. In my case the HV pulses are being generated in relation to the battery negative/ground (FET Source) and so I can't connect the negative of the capture cap to that as it will discharge straight away.
    I wondered if you can think of a simple solution to this?
    Regards,
    Jules
  6. #136
    Hi mml,
    Regards,
    Jules
    Hi Jules,
    here is a solution that works, with a second battery.
    In red: the circuit of the current when the coil collapses (Note: B1 does not discharge during this time, it just lets the current flow).
    You can think of other solutions.
    cordially
    mml
  7. #137
    Senior Member
    Oct 2017
    103
    A Solution
    Hi mml,
    Based on your thinking I have one idea that might work that keeps my current battery setup with the swapper. As the problem is around the common ground line for the batteries and the capture capacitor, can't I just switch the positive line instead of the negative with the FETs in the circuit. I attach the basic idea.
    Jules
  8. #138
    Senior Member
    Oct 2017
    103
    Like this . . . Looking back at SG Intermediate, where similar things are discussed, it appears that switching the positive will work just as well. The only downside is the 0.6V loss from the extra diode in the line but given that the capture cap will always be above the 36V battery voltage I might be able to dispense with it.
    Jules
  9. #139
    Senior Member
    Oct 2017
    103
    Revised Circuit and Update
    I have attached the latest circuit that I think should work based on the earlier designs of others. I had got R5 & R6 connected up wrong (as shown in the attachment in the previous post) and which would have shorted out D2 so have corrected that. This circuit also switches the positive line since that dovetails much better with my generator design. As I understand it the two pots, R10 for the lower and R13 for the upper threshold, are adjusted once the circuit is operating via scope measurements.
    My second attachment indicates some suggested values for these upper and lower thresholds in the charge and discharge cycle to use with a 36-38V battery system but if these are not reasonable then please let me know.
    The last two pics show the cap dump circuit build so far. The two FETs and the BJT are located on a clip heatsink under the circuit. When I have got my HV output back to where it has been I will see how the cap Dump Circuit behaves. What are the odds on it working first time? lol
    My overall aim here is to improve on the capture of ZPE at higher frequencies since my measurements indicated that the battery was not able to absorb the energy as the HV pulse frequency increased (best was 150-200Hz). If the capacitors are able to respond much better to the higher frequencies and then transfer that energy as regular 'hot' current pulses to the batteries, I might get closer to a linear response of energy absorbed with frequency. While some theory suggests that invoking ZPE is directly related to the voltage gradient of the HV pulses and that the amount of current flowing in them is not that important, I have noted that the higher the circuit/coil current the better the charging so current must have some role to play.
    If using the cap dump circuit makes no significant difference then I will have done all I can over the last year to produce an electronic generator based on induction and ZPE and will move on to something else.
    Regards,
    Jules
  10. #140
    Senior Member
    Oct 2017
    103
    Problem
    Well I was hoping for a smooth operation of the cap dump circuit but something is not right in the way it is integrating with the rest of the generator. When I have the generator working and showing HV pulses via a potential divider board (20:1 ratio - see pics of pulse) everything is fine but as soon as I divert the HV pulses to the capture capacitors the coil FET sometimes stops working. This has happened a few times but maybe due to some intermittent fault. One of the advantages of using capacitors is that they present a low impedance to the HV output from the FET Drain so might this result in an overload? Interestingly the HV pulses shape is much sharper than before having lowered the resistor value between the Gate and Ground from 15K to 2.2k.
    What I believe I have built is shown in the third pic.
    Any thoughts would be appreciated.
    Regards,
    Jules
