Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: Pulsing a coil with a cap pulser
    Greetings fellow experimenters!
    Sorry I have posted here for a long time.
    I was working on an experiment over the weekend where I was taking the output of a Bedini Large Comparator to pulse a very large coil. Then I sent the output of the coil to a battery.
    So far the results look impressive.
    Has anyone else tried this experiment?
    Cheers,
    1,473
    Cheers,
    Hi JK,
    Very long time indeed!! nice to see you back!! This experiment can it not be done with out the Large Comparator... I mean a set up which has a standard Vanilla SSG and just that a Capacitor in place of the primary battery!!
    just my opinion that the Generator mode and standard mode flipp their positions in this case.
    the nature of the spike at the output is also inverted to the case where we have a primary as the battery. In this set up i would place a Capacitor at the out put connected to the now generator mode and not a battery.
    Hi JK,
    You could use a smaller cap pulser, but I'm using the Large Comparator because the coil is my 81 strand #23 @ 3 ohms per strand. (It's a BIG coil).
    I'm not using an SSG circuit. it's set up like a 3 battery switch and the coil is the load. Will post a schematic when I get some time.
    Anyway, anyone tried this experiment?
    1,473
    Thanks JK! Yes i realize that the SSG circuit is kind of akward to this topology especially when using Transistor to switch Capacitor dump (how knows a SSG circuit using a Power device dual to the IGBT say like base and source and drain)
    when you said its a Big coil i'm sure it meant low impedance, High- Inducatnce...and all these are Paralleled (81 strands) @ 3ohms per strands must not be very high turns ration.for that gauge.
    any way more as i learn more..
    Best Regards,
    Best Regards,
    Best way to learn is to do the experiment
    Hi John,
    Not having an 81 strand coil could you let us know what results you have been getting?
    John.
    Cant spend it when your dead.
    1,473
    Hi JK,
    The Load coil seems to have primary and secondary sets of coils depcted in the second schematic next to it, represented by a SSG type (not actually one) and then an Inverter in parallel to the out put battery.
    The second schematic is the same as Peter L. presented in the 'beyond the advance' presentation.
    .......time to try out what it does??? double stage amplifier??
    1,473
    Hi John,
    John.
    @all odd number of coil
    1,473
    You said it JK...Indeed!!
