Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: Pulsing a coil with a cap pulser
    Hi John,
    With your 81 strand coil, how many strands are used as the primary (pulsed by the Large Comparator) and how many are used as the secondary to collect the radiant spikes?
    Hi Gary,
    The load coil is 81 strands of #23 (0.5mm), 64 strands are being used for the "power" winding and 16 strands are used as the "output" winding.
    1 strand is not connected (it was previously used as a trigger winding on another experiment)
    1,513
    Red face
    Hi Gary,
    Hi JK,
    Is the coil specifically designed for this experiment and why 81 strand in that ratio? 64 Primary and 16 secondary (and 1 'not in use')kind of Coupling ratio.. Faraday's equation would have said it be Turns ratio for a conventional transformer for Voltage.. Wow! This is Teslian coupling ratio for Current amplification right?? look i answered my own question !!!
    how about a Capacitor alone in place of the Comparator unit..since not all have access to it now??
    ofcourse it still needs to be 'rung twice'
    Faraday, no the coil was not specifically designed for this experiment. It's the same coil I was using on my SS SG.
    Don't over-think this, it's not that difficult. You can pulse the coil any way you like. I already explained how it works. Now there's even a proper schematic. Anyone who's been around for a while should be able to build something in about 20 minutes to prove the concept.
    1,513
    JK,
    Thanks for that little help! however, your schematic earlier shows the primary coil in series with the charge battery while the secondary is 'kind of parallel' via the conversion in FWBR.
    Since i do not have the Large Comparator... I would in essence have the Capacitor Discharge through a SCR or a MOSFET,(Transistors will not survive for sure) the SCR would Self commutate due to Series Resonance action but with this startegy you cannot make the 'bell ring twice' so Dual MOSFET is the best bet. BTW this is true even with Battery based primary switching..a cousin of the SSG.
    just my way of tinkering...
    thank s again... lets experiment..
    JK,
    Faraday, you don't have to do it exactly the way I am. Think about it - in it's simplest form it's a 3 battery switch that pulses a coil and then captures the spike into the third battery.
    You could do the switching easily with 1 transistor and a 555 timer. Would cost about 50 cents in parts to do that.
    1,513
    Hi JK,
    If it is BJT (Bipolar Junction transistor) MJE15024 should be ok...hmmmm..
    one transistor and Ringing it twice...ok !
    I appreciate your knowledgeable comments here, John.
    Would you be so kind as to make a quickie schematic of such circuit including battery voltage and amp hours and also coil number of turns, wire gauge and type of core, air or iron, nothing exact, just off the top of your head approximate numbers?
    A 12 volt 100 amp hour battery would be a good example but I can scale up or down from whatever you choose.
    555 timer circuits are plentiful so if you can just "black box" diagram that part and show the frequency.
    Thanks.
    Hi Richard,
    Here's a simple schematic. I'm not going to list component details, that's up to you guys to experiment with. The batteries you're planning on using will determine the size of the coil, the transistor, etc., etc.
    Simple 3 Batt Switch.pdf
    This is about as easy as I can make it.
    Hi JK,
    Faraday,
    I have absolutely no idea what "ring the bell twice" means. If you want to paraphrase that quote to suit this set up, knock yourself out. I'd rather use "really efficient battery charger".
    1,513
    Faraday,
    JK,
    'Tesla Impulse Technology'...thats all I too meant.. It was my contension to try the experiment to acheive the same thing without the access to the Large Comparator! in my opinion the Comparator is already doing the TIT part, with the circuit you showed, it does another level of amplification of the gain in the connected battery.
    Best Regards,
