Results 1 to 6 of 6
Thread: Kromray ish Converter project
    Mar 2018
    Near Queenstown New Zealand
    3
    Attached Files Attached Files
    Mar 2018
    3
    Testing Testing
    1,241
    I saw it, looks like a Bedini-Cole motor. Are you familiar with that?
    It seems to be like this:
    Except you have the coils rotating where the magnets are and between the coils you might have permanent magnets. But the plane your spinning it on is the same, which is 90 degrees to the Kromrey.
    1,394
    @Alternate,
    Yes there is another thing you can grasp from that archival diagram..
    shown but not emphasised.. look at the connections between the coils it speak a lot about the Kromrey and the G-Field.
    once you understand the kromrey....the G-field is one wire away..
    good luck,
    'The Magnetic Field is the gatekeeper of the Wheather on the Earth'' - John Bedini.
    Mar 2018
    3
    Yes I am going to give G-Field type coils a go first, but will then try coils of wire at each end and not a full Iron core connection between each end. Like the normal Kromray would have may even need to but a small brass rod in each reduced iron section, just in case that has something to do with the effect. But will see.
    Alternate
    1,394
    Quote Originally Posted by Alternate View Post
    Alternate
    Hey Alternate,
    The need to have brass shaft is to avoid magnetic 'shorting'..remember the G-field and the kromery generators are Flux gate machines.. which means poles switch between the gaps..this is critical if you are to see the effect. the conventional sinosidal wave gets converted to longitudial wave of Tesla- impulses.
