Complete Bedini SG Book!
  • #91
    Hey guys ,
    Thanks again for the bedinisg ebook , If it wasn't for that ,I would still be like
    a dog chasen his tail trying to figure out , how in hack does these ssg machine fit together.
    • #92
      Hi everyone, (Built by bedinisg ebook) machine.
      Why do I only get periodic spikes when I am trying to get one on every cycle?
      Input is Welcome!
      24 volt setup.
      • #93
        it is just the sample rate on your scope and how it catches the pulse, and how it can redraw the screen. looks good, I dont see the hi peak every peak on my digital scope, easier to see on my analog one.
        • #94
          Assuming all else is perfect, it could also be due to the magnet to coil relationship...
          K.R.
          • #95
            Thank you , (Built by bedinisg ebook) Machine
            Tom c and Patrick for your input
            A quick scope shot without charge battery, 1 neon popped while doing this
            • #96
              [ATTACH=CONFIG]1349[/ATTACH]
              uh.... dont do that, you may have damaged some transistors, if you popped a neon you definitely want to check the transistor that it was attached to.
              • #97
                Tom C (Built by bedinisg book) machine
                Should of mentioned, in post #92 , it is a 24 volt setup,
                but in post #95 it is a 12 setup, so maybe it is still ok , but I will check out
                Thanks for you input!!!!
                • #98
                  Hi all (Built by bedinisg ebook) Machine
                  Tom C . and Patrick , for yor Input.
                  Under standing mine scope better
Name:	scope shot update.jpg
                  John Bedini for your GREAT Work
                  • #99
                    Great job on bringing this book together.
                    Have not seen this question posted on this thread.
                    Been looking for the exact spool referred to in the book = 3.25 inches high, 3.5 inches in diameter, central cylinder .75 inch diameter.
                    Closest have been able to find is over at:
                    10 Spools used with Regular size Bedini Monopole Energizers.
                    = 3 3/4" H by 3.5" top and bottom, 3/4 bore.
                    Does it need to be exact or will the above work?
                    Anybody have a source for the exact one specified in the book? = 3.25 inches high, 3.5 inches in diameter, central cylinder .75 inch diameter.
                    Thanks again,
                    IndianaBoys
                    PS - also looking forward to Book 2 and Book 3 when they are available!
                    • Originally posted by IndianaBoys View Post
                      Thanks again,
                      IndianaBoys
                      Hi IndianaBoys,
                      Where are you located? I have some of the correct size in Australia and know someone in the US who has some as well.
                      • There is still tuning info in this thread and info on cycling batteries I believe.
                        Good Day Aaron (Built by bedini ebook) machine
                        What you mentioned here , If mine tunning is ok, I am ready for the battery cycling info.
                        Help wanted
                        • Bedini SG Spools
                          Thanks for the offer.
                          Have moved forward using some Schedule 40 pipe 3/4" nominal size. It has an ID of .804, which is .054 inch off of the .750 inch diameter called for. Had some ABS sheet to use for the end plates and glued it up. Maybe posting this will help others.
                          IdianaBoys
                          • Originally posted by powermanch View Post
                            That should probably be discussed in another thread since that topic is not covered in the beginner's handbook.
                            Anyone know if that is discussed in another thread here already?
                            • Battery swapper experience ? (my side project)
                              Aaron there is a thread started by BEDINSSGUKRAINE
                              is that the place to go ?
                              • Here where I live is a real pain to find r45 welding rod type for core...I found instead this:
                                http://www.imosdg.ro/cataloage/Fisa%...likon_mg-2.pdf
                                Can somebody take a look and let me know if this type of wire is ok?
