Page 10 of 21 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 204
Thread: Complete Bedini SG Book!
  1. #91
    Hey guys ,
    Thanks again for the bedinisg ebook , If it wasn't for that ,I would still be like
    a dog chasen his tail trying to figure out , how in hack does these ssg machine fit together.
  2. #92
    Hi everyone, (Built by bedinisg ebook) machine.
    Why do I only get periodic spikes when I am trying to get one on every cycle?
    Input is Welcome!
    24 volt setup.
  3. #93
    it is just the sample rate on your scope and how it catches the pulse, and how it can redraw the screen. looks good, I dont see the hi peak every peak on my digital scope, easier to see on my analog one.
  4. #94
    Assuming all else is perfect, it could also be due to the magnet to coil relationship...
    K.R.
  5. #95
    Thank you , (Built by bedinisg ebook) Machine
    Tom c and Patrick for your input
    A quick scope shot without charge battery, 1 neon popped while doing this
  6. #96
    Quote Originally Posted by powermanch View Post
    uh.... dont do that, you may have damaged some transistors, if you popped a neon you definitely want to check the transistor that it was attached to.
  7. #97
    Tom C (Built by bedinisg book) machine
    Should of mentioned, in post #92 , it is a 24 volt setup,
    but in post #95 it is a 12 setup, so maybe it is still ok , but I will check out
    Thanks for you input!!!!
  8. #98
    Hi all (Built by bedinisg ebook) Machine
    Tom C . and Patrick , for yor Input.
    Under standing mine scope better
    John Bedini for your GREAT Work
  9. #99
    Great job on bringing this book together.
    Have not seen this question posted on this thread.
    Been looking for the exact spool referred to in the book = 3.25 inches high, 3.5 inches in diameter, central cylinder .75 inch diameter.
    Closest have been able to find is over at:
    10 Spools used with Regular size Bedini Monopole Energizers.
    = 3 3/4" H by 3.5" top and bottom, 3/4 bore.
    Does it need to be exact or will the above work?
    Anybody have a source for the exact one specified in the book? = 3.25 inches high, 3.5 inches in diameter, central cylinder .75 inch diameter.
    Thanks again,
    IndianaBoys
    PS - also looking forward to Book 2 and Book 3 when they are available!
  10. #100
    Quote Originally Posted by IndianaBoys View Post
    Thanks again,
    IndianaBoys
    Hi IndianaBoys,
    Where are you located? I have some of the correct size in Australia and know someone in the US who has some as well.
