Results 1 to 4 of 4
Thread: 1 watt 470 ohm resistor
    Can anyone give me a link to the 1 watt 470 ohm resistor on Mouser. I am not sure about which one to order based on what is offered on Mouser.
    1,470
    Quote Originally Posted by mche36500 View Post
    1W 470 should be available in any Radio shak not a very critical tolerance item..
    are you buying in quantities..??
    ‘Mass is spatial density of Matter (Particle) and Temporal density of Space (Field)’.
    I need a total of 7 1W 470 Ohm resistors for the Bedini SG project build.
    Hi mche36500,
    Here's the link you requested. At least this is the one I would get if buying from Mouser. https://www.mouser.com/ProductDetail...uDN2p3v8YlQ%3d
    However, I bought the 8 transistor kit from Teslagenx which has everything you need, and all the critical components are already matched! You will probably spend more if buying enough transistors and resistors individually to get everything matched for best performance. Check it out here. http://teslagenx.com/kits/tx-sg8.html?category=kits
