Bedini RPX Sideband Generator
2019 ESTC ALL SEATS SOLD OUT!
PRE-REGISTER FOR THE
2020 ENERGY CONFERENCE
Monero XMR
Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 92
Thread: ZFM Advanced Explorations
  1. #81
    Wow! Thanks James! Really cool to see the coil impedance measurements. Would you happen to have a pic of the Bedini-Cole Switch PCB you designed up for Yaro? Attached is the design I'm working on. Wondering if having a double layer pcb will have a negative effect on anything...
  2. #82
    Senior Member James McDonald's Avatar
    Join Date
    Jul 2012
    Location
    Odenton, Maryland
    Posts
    130
    Hi Joster --
    See the attached picture of the PCB board.
    -- James
    Attached Images Attached Images
  3. #83
    This is great thanks so much! I have a few questions:
    1. What are J3 and J4 for?
    2. What are D1 and D2 for?
    3. My pcb design is 2 layer. Should I try and do it all on one layer as you have it here?
    4. Trace width? should the traces not be wider? at least for the coil connections to facilitate a low impedance path to extract the radiant energy? You likely know better than I as I haven't done much pcb design so I'm just confirming.
    Thanks again,
    Joster
  4. #84
    Join Date
    Jul 2012
    Location
    Odenton, Maryland
    Posts
    130
    Quote Originally Posted by Joster View Post
    Thanks again,
    Joster
    Hi Joster --
    Sorry for the delay in me answering your questions but I only check this forum once a week now
    or just on the weekends. It is good to ask questions here due to we are also teaching others and
    hopefully others will take an interest and build there own ZFM also. I myself started out using a
    cheap PCB design software package called DipTrace but I now use Altium Designer 19.
    "1. What are J3 and J4 for?"
    On the original design there were 4 coils. So J1 through J4 are for a 4 coil ZFM.
    I myself only used two coils and put jumper wires on the ones I did not use since
    all 4 coils were connected in series with each other. So for a two coil ZFM design
    you would use J1 for coil 1, J2 would have a Jumper wire, J3 would have a Jumper
    wire, and J4 would be for coil 2.
    J1 through J4 were for coil inputs.
    J5 and J6 were for Timing Reed switch inputs.
    J7 was for if you wanted to relocate the power On / Off switch somewhere away from the PCB.
    J8 was the external Power input to the PCA.
    "2. What are D1 and D2 for?"
    I had told you that in the pictures I sent some of the parts were not soldered to the PCB
    yet. D1 and D2 are important to trouble shooting the design. They are LED's. Before you
    even apply power to the ZFM you can see these LED's light up just by spinning the rotor
    by hand. When they light up without power applied it tells you the coils are wired to the
    PCB correctly and the reed switches are wired up correctly and not broken. They are also
    an indicator if a transistor happens to go bad you can tell which 2 of the 4 are not working.
    The LED's are help in adjusting the timing on the ZFM. If the timing is off you can see it in
    how bright the LED's are.
    "3. My pcb design is 2 layer. Should I try and do it all on one layer as you have it here?"
    My PCB is a 2 layer also. You should use your 2 layer PCB. It makes soldering much easier.
    What you would do is, try to get every hole that would go to the bottom layer to have a part
    pin going through that hole.
    "4. Trace width? should the traces not be wider?
    Depending on how big your PCB is and the way the parts are laid out on it I made my traces
    as wide as the connector pins and part pins they would attach to and in between power busses
    were all made as thick as possible without causing shorts.
    "5. at least for the coil connections to facilitate a low impedance path to extract the radiant energy?"
    For my ZFM design the coils were wound with 18 gauge wire and I used 450 feet for each side to
    get the coil resistance to be around 3 ohms. This made a 6 ohm coil when put in series. The
    transistors being used are used to pulsing current through the coils and since they are Audio
    Transistors they are used to driving speakers from 4 to 8 ohms. The little bit of impedance on the
    PCB will not have any effect on the whole circuit operation.
    I am not sure if you saw the below video I made in front of my townhome this summer but the
    link is below.
    https://www.youtube.com/watch?v=-sDcE_xCZS4
    -- James
  5. #85
    Senior Member Yaro1776's Avatar
    Join Date
    Aug 2012
    Location
    Heart of Vermont
    Posts
    344
    YZFM Done Deal
    Greetings to all,
    This post will close out the YZFM explorations for the 4 pole rotor configuration of the ZFM. The last recent experiments verified the May 2019 test results and increased the load on the motor up to 1.0 kg. The results are as follows:
    5504 RPM at 60.14v and 1.80A with 0.49 ft lb load: eff. 29.29%
    5063 RPM at 60.78v and 2.20A with 0.55 ft lb load: eff. 24.65%
    10800 RPM at 60.0v and 1.02 A at 0 load
    The loading was at the limit of the torque testing apparatus - need a new arrangement for higher loads. The left coil on the YZFM was overheating? while the right coil was at a comfortable touch temperature.
    To flesh out the testing the power supply was changed from the linear transformer PS to three LAB's at 36 volts nominal just to cover all bases. Results are as follows:
    4075 RPM at 36.80v and 1.59A with 0.36 ft lb load: eff. 29.91%
    7480 RPM at 37.17v and 0.66A with 0 load
    All the above data falls into the range of the prior testing. The only outlier is the high left coil temperature. So this test concludes the testing for this configuration over a nearly three year span. The information gained from this effort will now be applied to the next version.
    Please note that Dr. Peter Lindemann did mention to me and in a forum post that the 4 pole ZFM air core coil arc should really be reduced to about 80 degrees instead of existing 90 degrees of the YZFM. I have had the sense for a time that this build has been somewhat restrained by other factors. Dr. Lindemann never explained the why of the 80 degrees - another puzzle that I will attempt to clarify by a simple demonstration in the future in the new thread for the next version's build. This may be a very important point.
    BTW, when the YZFM was torn down it was discovered that that left air core coil (the one that overheated at high load) had some internal shorting issues. Unknown when it was actually damaged since there have been a number of relatively violent Neo failures in the past two years.
    Happy Fall,
  6. #86
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,438
    Blog Entries
    1
    Thanks for the update Yaro!
    Do you know what kind of insulation is on your magnet wire?
  7. #87
    Join Date
    Aug 2012
    Location
    Heart of Vermont
    Posts
    344
    Wire is from Essex - #20 amber colored, Insulation Base coat - modified polyester; Overcoat - modified amide-imide rated for 220C temp. The characteristics of the motor have changed with time - it has been shipped cross country twice and experienced three Neo failures (one without the safety tape) at speeds over 8000 RPM.
    Coil is quadfilar so it may be that one or two strands may be suspect/intermittent, beyond that I have no clue. I am not inclined to re-wrap/repair the suspect coil at this time.
  8. #88
  9. #89
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,438
    Blog Entries
    1
    Quote Originally Posted by Yaro1776 View Post
    That insulation is a bit beefier than what I've been using so it must have taken quite a beating: https://temcoindustrial.com/23-awg-c...l-gpmr200.html for mwo hv coils.
    Those coils are 1 layer and we put 10 coatings of super corona dope on top so they can hold up to quite a bit! That stuff will hold back about 3500 volts per mil without even baking it - baked is about 4000 volts per mil or more. It dries like a glass coating - anyway, in case you ever want to go that far with the coils, that's the stuff to use.
  10. #90
    Join Date
    Jul 2012
    Location
    Odenton, Maryland
    Posts
    130
    All sounds great! check this out....
    Hi Joster --
    That is a very nice looking setup you are working on. Tell me how you are going to connect the four wire? Series??? Parallel??? or Combo of
    both series and parallel?
    -- James
Posting Permissions
  • You may not post replies
  • You may not edit your posts
