Does this mean you no longer need the magnet on the back of the coil to get it going?
You can hook the DMM to the negative side of the battery OR to the positive side of the battery. Just put it inline from battery to circuit. It's nice if you have a bypass switch so you can get it running, then throw the switch to check current, then throw the switch again to get the DMM out of the circuit. Depending on your DMM, you could lose speed and charging having it in the circuit. It's also a good idea to only use your multimeter very intentionally and minimally as it can blow easily when you inadvertently introduce it to spikey.
