Page 11 of 11 FirstFirst ... 91011
Results 101 to 109 of 109
Thread: Bedini 1984, 2017 style.
  1. #101
    OK, you are showing 8 strands with 2 strands in parallel on each coil, and 4 coils in series, is that correct...?
    And if so, you should make the 2 strand coils hooked up as series connected strands as well as connecting the individual coils in series... and then you need to put that output into a cap pulser, and or do the Konehead Ring the Ring trick to boost the genny energy collection into the cap pulser.......
  2. #102
    Yes its an 8 Strand coil with pairs of strands in parallel.
    These pairs are in series.
    Early days yet, but yes thats the plan.
    Heres a chart of this coil in the 3 different combinations.
  3. #103
    @RS and others It was my response for the Truth seekers not for hooligans!!!
    Faraday, can you please stop detracting this thread. From what I've read you haven't added any valuable discussion to the research Deuis is doing.
    Unless you can add something meaningful to the thread I'm going to have you banned. There will be no further warnings.
  5. #105
    Wow! that is cool. Although I'm having trouble seeing all of the images, aside from the 15 thumbnails. I can only see a full sized version of the first image.
  6. #106
    I've been testing my SG with various magnet combinations to see how spacing effects performance.
    12V primary. Same trigger resistance. 26" wheel.
    6 magnets, 77hz, 210V peaks, .7A primary per coil.
    18 magnets, 222hz, 212V peaks, 2.4A primary per coil.
    36 magnets, 299hz, 216V peaks, 3.1A primary per coil.
    I thought that the tight magnet spacings would effect the peak V but this hasn't been the case.
    It does seem to have an effect to the top speed of the wheel however.
    The 36 magnet wheel running 299hz was pushing a 12V x 100ah battery to 13.2 fairly quickly.
    Cant spend it when your dead.
  7. #107
    Heart of Vermont
    353
    Hey John,
    Looks like things are getting very interesting in this experimentation - love the set-up!
    Keep up the good work and thanks for sharing...
  8. #108
    Deuis,
    Great Setup, Great Experiments, Good Job.......
  9. #109
    Hi RS,
    Could please elaborate on the 'konehead ring trick' I guess it has something to do with the coil shorting methods..
    Thank you in advance.
