Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Bedini SG Monopole with Capacitor Discharge
    Here is the circuit of the Bedini SSG Monopole with Capacitor Discharge.
    Hi John K,
    What are the specs on the coil? Would you use a coil similar to the ssg but with an extra 23 gauge wind for the secondary? So a coil with one 450' wind of 26 gauge, and two 450' winds of 23 gauge wire?
    thanks,
    Robert
    Quote Originally Posted by Robert Darrah View Post
    Hi John K,
    thanks,
    Robert
    Hi Robert,
    It depends on the size of your machine and the batteries you want to charge. You could use the wires you mentioned for a small machine, or you could use 3 x 130' of AWG#18 for a larger one. This is something you should experiment with.
    Hi Johnk,
    I've ben working with a cap discharger and using IR switching.
    At the moment it is running with one switch keeping the trigger circuit on for about 85% of the time and a 2nd sw to pulse the run batt once per rev. 16" bike wheel.
    It looks decent. I'll probobly add an isolated gen coil and combine the output to the cap and switch the cap into the run batt 2 times per rev.
    My cap voltage at present is about 30v with a 12v run batt.
    The cap discharge will do a nice job of charging a batt. I'm not using a diode off the collector.
    bro d
    Here John and I are Showing the Alum battery on a monopole and the fast charge rate and impedience change. The alum batteries charged to a point within 3 minutes that the capacitive dump halted and charged the batteries up to a little over 15v in a fast time. John and I explain this in the video. Thanks for watching.
    Chuck Hupp
    I built one of the capacitive discharge monopoles according to the circuit posted on this thread. I tried to get everything as close as I could to the original specs. The exceptions were I couldn't find a 2N3584 transistor so substituted with an MJE15032. For the base resistor I had to remove the 680 ohm one and ended up at 20 ohms for best tuning.
    I used a 26" bike wheel for the rotor with 18 magnets in standard arrangement. The coils is a non-litzed 3 filar, all 18 gauge 130' long. Here are a couple of pics:
    This hot pink girl runs at 254 rpms, is drawing 1.26 amps from the primary and is charging .253 into the charge battery. I charged up a 3.5 ah sla battery in about 6 hours just to see what it would do, and I'll next try a lawn and garden battery to see if it's close to the c20 rating, which I expect it should be given the results from the 3.5 ah battery.
    Here are a few notes for anyone building something similar. I put a panel meter on the charging side but wasn't seeing any fluctuations, only a steady current flow. Ditto with the dmm. So I started troubleshooting it to see if it was working right. I started by putting the scope probe on pin 3 for the 555 timer and the ground on the neg of the primary battery. This gave me a nice square wave so I knew the timer was operating like it should and sending a square wave to trigger the opto.
    Next I put the probe on the base of the MJE15032 and the ground on the charging positive to check the signal to the base, and I was getting a square wave with rounded corners, so I knew the opto was firing and sending a signal to the MJE15032. This was the transistor I suspected in case there was a problem, because it was a replacement for the original.
    So now I've got a trigger to the MJE and next I checked for a trigger to the gate of the SCR. I put the probe on the gate and the ground on the charging negative and again I've got a signal.
    So far so good, as I've got a trigger to the SCR. Next I put the probe on the cathode and ground on charging negative to see if the SCR is firing. The wave I got was a spiky little thing that wasn't what I expected, just little short spikes at even intervals. The voltage was a lot lower than I was expecting and it was just a vertical spike, so really fast. It looked like the cap was firing at regular intervals but I wasn't getting the kind of wave I thought I would get.
    I was expecting a wave more like I got from the ss kit I got from rcharge, a much longer and rounded wave as the cap charges, but the cap on this build is only a 3.3uf one, as compared to the 560uf cap on the kit, so I thought that might account for the difference in wave forms.
    I then took a 560uf cap and put it in parallel with the 3.3uf and then I started to see more what I expected:
    I think at this point I started to see some fluctuations on the panel meter. Another difference between my rcharge kit and this build is that the resistor on this build that times the intervals between pulses is 51k, and on the rcharge kit it's a pot that goes up to 2M.
    The higher the resistance for that resistor means the longer it takes for the timer to fire the opto. This means the cap is charged for a longer amount of time, and charges to a higher voltage before discharging. You can see this in the next wave where I increased the timing resistor from 51k to 271k and had the 560uf cap in parallel:
    So what I've got now is stair step charging. Cool. What is happening in this wave is the coil is getting 10 magnet passes before the cap discharges, and you can see the 10 steps in the wave where the cap is being charged. Each pulse from the coil charges the cap a little higher. Really cool. At this point I'm also getting much larger and slower fluctuations in the panel meter and everything is looking ok.
    What I'd learned, and am passing on to anyone that is building this for the first time, is that the 3.3uf cap is small and the 51k resistor is fast, so you get a lot of quick, relatively low voltage discharges from the cap that won't show up on the panel meter or a digital meter, and yet the cap is discharging like it should. If you're not sure your build is discharging like it should, then you can increase the timing resistor and cap size like I did and see the cap discharging on a panel meter for visual verification.
    This is a fun little circuit to build and a good intro to the discharging the cap part of the technology. It's also a good basic system for experimenting with changing the timing resistor and size of the cap, so you can learn what the effects will be on the charging battery.
    Another observation I wanted to make is that with a ceramic magnet my compass will deflect slightly to over a foot from the magnet. I've got a steel toggle switch about 6" from the magnets on this build, and the alligator clips on the battery are probably in range of the magnets also, so while the effect is probably slight, this isn't going to help my cop any. FYI.
    Cheers,
    Robert
    Robert,
    Great build thanks for sharing, looking forward to your test results.
    I want to make a solid state version of this. One question though.
    Isn't there a spike on the primary coil? What protects the transistor on the primary coil?
    In all the ssg circuits I have seen all the power coils have an output to a battery with a neon lamp for protection/alerting.
    Quote Originally Posted by bluestix View Post
    the full monopole is a different beast than the SG you can build it just like it is designed.
    How many output coils can you make per input coil?
