Page 35 of 36 FirstFirst ... 2533343536 LastLast
Results 341 to 350 of 353
Thread: Kromrey Disclosure - Bedini SG - Beyond the Advanced Handbook by Peter Lindemann
  1. #341
    Hi RS_,
    Just wanted to mentioned that I found what you are talking about "Back Popping" the primary battery. JB talked about this in his 2013 presentation, adding a diode for "Generator Mode" that causes the unit to use a little more power and caused the charge battery to charge faster by putting the batteries into a "common ground" mode of operation. I knew I seen something somewhere about an added diode to the SG setup and PL explains about it in chapter 2 of the 3rd SG book, different names for the same thing does confuse people.
    Take care...
    rdvideo
  2. #342
    That's Not quite what is meant by back popping the primary battery. The Watson machine uses 1 version of back popping, by filling up a cap with the generator rotor / coils, then disconnecting motor/driver from the battery and then dumping the cap into the drive battery, and then reconnecting the motor/driver while the cap builds back up voltage....
    I've use a mosfet between the pos of the battery and the pos of a motor driver circuit, and a 2nd mosfet between the neg of the battery and the neg of the motor driver circuit. this lets you completely disconnect the motor driver circuit from the battery and the motor driver circuit can continue running from a cap on it's side of the 2 mosfets
    so if you have a genny coil filling a big cap/ cap pulser, and pop the drive battery while it is completely disconnected from the motor driver circuit then reconnecting it back to the motor driver circuit with the mosfets, after the Cap dump......
    PL's 2016 presentation shows how to back pop a charging battery with a modified SG and I did the same thing in my 2017presentation
    Here is the Schematic that I shared with some of the People at the 2016 conference
  3. #343
    Thanks RS_ for sharing the schematic which is rather complex by looking at it and you like to squeeze as much as you can onto one page and not easy to read.
    Now your explanation of back popping the drive battery reminded me of what I read about back in 2013 and trying it with my bike wheel SSG version then; using an extra coil to capture energy from the magnets charging a cap, that are arranged N-S-N-S on the bike wheel according to Rick was-his-face schematic back then before JB broke ties with him. The one thing about charging of the drive battery was to disconnect the drive battery to give it a charge and then connect back to ckt to keep going. I have to watch PL's 2016 presentation again to see what I missed. I think that Daftman also posted a pic of his ckt using a relay to disconnect the primary battery to give it a pulse.
    I found my folder of everything JB related from 2013 and also includes from then, Bedini Monopole 3 Group Experiment I downloaded and was following it back then and using a Spreadsheet to record the charge/discharge of the charge battery from my bike wheel experiment. I'm sure that there are some members that remember that time...
    rdvideo
  4. #344
    Hy guys.I have built the g-field gen type gen and bogs down under short.I give credit to VacuumEnergyMan'',BaFe magnets is hogwash to keep people from replicating this.VacuumEnergyMan said he conected the coils like in the patent and got nothing,well i got the same results nothing at the output but i got it to accelerate.The coil arangement in the patent gives 0v out because the coils are canceling each other out.The whole secret is coil config
  5. #345
    1,398
    Quote Originally Posted by adys15 View Post
    I released a video on YouTube showing exactly what the coil configuration is.
    It's also included in the package with Peter Lindemann's presentation on the Kromrey.
  6. #346
    Thanks Aron,i saw your videos but you showed the electromagnets coils,i.m interested in the rotor electromagnets..if there are wound like in the patent they cancel eachother
  7. #347
    1,398
    What are you calling the rotor electromagnets?
    The generator coils are rotating and could be considered rotor electromagnets.
    Instead of permanent magnets that induce current into the rotating electromagnets, those could be electromagnets as well, but those are not rotating. Please clarify.
    If you mean the stationary ones, you need to wind them so they have the same magnetic field polarity as the permanent magnets.
  8. #348
    1,510
    The original Raymond Kromrey Patent depicts an Electromagnet for the Field excitation. it carries the same excitation current as that carried by the Rotor coils. Remember the Kromery patent talks more about it as a 'Low-drag Generator' and NOT as an 'Energizer' John Bedini perfected the design to explore the 'Energiser' aspect of this configuration and unveil the Radiant Electricity which was the basis of it. he then termed it as the G-Field Generator. Please watch his DVD on the Kromery convertor.
    just my few cents...
    rgds,
  9. #349
    sorry i meant rotor coils,can someone make a good diagram of the windings that we can all take for granted and experiment with those
  10. #350
    1,510
    Its there in the video that Aaron referred to...
