Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 118
Thread: Bedini RPX Sideband Generators
    1,447
    Thumbs up Bedini RPX Sideband Generators
    Sideband Generator http://sidebandgenerator.com
    Sideband Generator NORMAL RETAIL $495 USD
    CONFERENCE SPECIAL $400 USD
    BY PURCHASING THIS CIRCUIT,
    YOU ARE AGREEING TO A NO REFUND POLICY
    20% Discount
    NEW BEDINI CIRCUIT $400
    USPS PRIORITY MAIL
    $15 SHIPPING TO USA
    TOTAL
    $415
    20% Discount
    USPS PRIORITY MAIL
    $40 SHIPPING TO CANADA
    TOTAL
    $440
    20% Discount
    USPS PRIORITY MAIL
    $50 SHIPPING TO INTERNATIONAL
    TOTAL
    $450
    PayPal or other online payment options are
    NOT available for the Sideband Generator.
    Send a check or money order for the TOTAL amount based on your location (US, Canada, or International)
    made payable to:
    A & P Electronic Media
    Mail it to:
    A & P Electronic Media, PO Box 10029, Spokane, WA 99209
    YOU ALSO NEED THE FOLLOWING ITEMS THAT ARE SOLD SEPARATELY THROUGH AMAZON
    Velleman HPG1 1Mhz Pocket Function Generator
    HiFi Banana Plugs
    (Connect your own electrodes and wires to these jacks)
    12v DC Power Plug with CENTER POSITIVE
    12v Battery
    FOR A HIGHER QUALITY FUNCTION GENERATOR,
    THIS IS THE EXACT RECOMMENDED UNIT:
    B&K Precision 4013B Direct Digital Synthesis Function Generator, 0.1 Hz – 12 MHz Frequency Range
    MAKE SURE TO SELECT THE CORRECT FREQUENCY RANGE
    FOR A SPECTRUM ANALYZER THAT WILL SHOW YOU ALL THE SIDEBAND FREQUENCIES AS THEY ARE PRODUCED,
    Rigol DSA815-TG Spectrum Analyzer
    Heart of Vermont
    347
    Hello Aaron,
    Thanks for putting together the wiring schematic and general specs on the Sideband generator. Some general pointers on use and on time would be useful and appreciated.
    1,447
    Website has been redone to reflect the free book & video offer http://sidebandgenerator.com
    Will also be posting more info on that page.
    Does this device produce Bedini's 4wave mixing, what else doe it do?
    1,447
    http://sidebandgenerator.com is updated a bit. It is not the same as the 4 wave mixing circuit. It creates a fundamental frequency that you "bounce" other frequencies off of it to distort it and like ripples coming off of it are harmonic sidebands that hit EVERY frequency along the way. That is a superficial explanation, but is essentially the idea.
    It is the most accurately reproduced Rife technology, which is actually hybridizes Priore and Rife with Bedini's personal touch. If you look at his book and dvd, you can see exactly what that is about.
    By purchasing one through http://sidebandgenerator.com you can get a free book or video of your choice available from http://emediapress.com
    The price will go up to $450 soon so so you can still take advantage of the conference discount.
    Thank for the reply Aaron, hope to try it out soon
    How can this be arranged with the one wire to the microscope slide for testing like Bedini shows on his website during the rense interview presentation?
    1,447
    Quote Originally Posted by Davy Oneness View Post
    Of course this is all just for experimental purpose without any claims.
    I made a 6 inch diameter pancake coil (single winding - not the bifilar type) using 5000v rated wire since it is very flexible like test lead wire... each electrode output will go to each end of the pancake coil. I can lay anything on the coil I want since it's flat. That is the route I'm going anyway.
    That sounds like a great way to experiment with it. It brings to mind a new question, what is the output loading restrictions? I'm guessing it is short circuit protected?
    Another possible way for slide testing, seeing that it is an rf generator, maybe one wire to slide fluid and other wire connected to foil that is under the slide.
    Perhaps this unit could use an amplifier output stage ?
    Perhaps I shouldn't but I'll throw some spaghetti at the wall. Well, I got nothing, how is this thing discriminant? If you say resonance, what is resonating? The obvious candidate would be DNA, the DNA acts as some sort of antenna leading to a building standing wave at the gHz frequency specific to a pathogen that makes a bug go kerploof. I was behind that in that in more complex organisms the DNA is usually enfolded (histones, epigentics et al.) while in more simple organisms the DNA would be out there to resonate, then I thought of mitochondria. I am not expert, but of course mitochondria have their own DNA, less controlled, regulated and folded, than that in the nucleus, much more like a bacterium. I don't know what JB presented, maybe he was trying to get across a way to purify water with this thing, but if one could, which wouldn't be easy, I would try to look at the mitochondria first. And no I am not saying oh this must be harmful, ascorbic acid somehow discriminates, as voluminously documented in the literature, between nearly all pathogens and all toxins and I have no idea how. Nobel prize winner Svent-Gyorgi who discovered Vitamin C felt it went back to the electron transport chain in the mitochondria. So if you could see whether this fries mitochondria, you would have an idea, though not firm, whether it is discriminating against single cell versus multicell. If it doesn't harm mitochondria, which I suspect, then one is back where I started, which is what the heck? Likely just some possibly tremendous health break through that can hardly be evaluated on a shoestring. Que Sera, sera.
