Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 118
Thread: Bedini RPX Sideband Generators
    Zenzete,
    John recommends only batteries for these devices for several reasons, but the best reason is the mains power is dirty in more than 1 way. any 15 is the limit for the on board voltage regulator.
    these boards posts are not moderated individually, and I cannot see Aaron taking the time to do that. sorry he has not answered you, he is usually very forthcoming with information and usually goes out of his way to respond. he is a great benefit to the free energy community.
    1,456
    Quote Originally Posted by zenzete View Post
    Tom C,
    Thanks for the link to the book and DVD. I have asked for that link and for other information on three separate occasions from Aaron but none of my messages have been approved for posting or answered. No explanation has been given. The Rife information has been known since 2008, but I would like to see what Mr. Bedini has made of it. He is very creative and may give me information that I have not considered.
    You are correct in the statement that you made concerning the FCC legality. There is a low limit output that is dictated by the FCC that cannot be enforced. I have turned my Rife-Bare device up to 300 watts and using a TriField Meter I lose the signal at about 30 feet. I doubt that in the midst of radar equipment and Part 15 devices that anyone will detect my 50 watt signal emanating from a plasma tube. I have adopted a practical outlook of regulations based on reality. Most repressive regulations are used for repression not safety or order. That said, I appreciate and respect your viewpoint. I don't intend to sell anything but you are correct on that point also. The exception to enforcement of the law is found in the personal use clause and the point of non-interference. If the signal is not detected outside your property boundaries and the device is for personal use or investigation, the federal agencies seldom take action even when they are aware of the device. If viewed from a legal point, anything can be done to prevent your investigation. The persecution of Royal Rife is a fine example. The control of the country cannot be in the hands of the people when they fear their own government.
    I don't know what messages need approving - every member here can post a message and it instantly shows up. As Tom mentioned, the messages are not individually moderated. That is way too time consuming.
    "The book and DVD combination (only sold together) can be purchased from this page, and for those with adequate knowledge, training and skills on the bench, the Bedini RPX can be built from the information in the DVDs and the booklet. Or instead you can buy the complete Sideband Generator from TeslagenX by clicking this link. The two DVD set alone runs over three and a half hours."
    http://energyfromthevacuum.com/Bedin...ediniBPRX.html
    I was referring to three different times that I tried to reply to your messages and the reply did not post. I thought I saw a brief message just before the screen refreshed but could not understand it. I did not see an error message or any other explanations so the time delay and approval was the only answer that was logical. Perhaps I did not understand this system. I am new here. I am learning though.
    1,456
    It's probably just a glitch - the database for vbulletin is known to do that once in a while.
    I'll be adding more information on http://sidebandgenerators.com including the pancake coil I'm using, vids of the sidebands on a spectrum analyzer, etc.
    Is the spectrum analyzer required to tune and use the device?
    1,456
    Quote Originally Posted by Wei View Post
    No.
    No tuning is required either - you just hook up the function generator with the right settings as indicated and it will do what it is supposed to do.
    Spectrum Analyzer is only needed if you really want to get deep into the research and learn more about the sidebands. The one we recommend is the exact one that John Bedini uses - https://www.amazon.com/Rigol-DSA815-...g=maimounas-20
    It's about $1500 so up to you.
    If you just want to experiment with the sideband generator, you do NOT need the Spectrum Analyzer.
    There are a few things in skew with the thing Aarons selling versus what Bedini himself called out in the booklet and DVD's from Bedinis/Craddocks site.
    1. the batteries should be specifically Lithium iron phosphate batteries, not lead acid nor lithium ion...
    2. the audio range used from the books is 10-70khz, not 50-150khz... as well the waveform is not "sign"/sine, its Square wave input.
    3. output from the RPX should go to a pair of tens like pads that would then be put on the body to add it in as part of the circuit on the RPX.
    Just a few things in skew, but enough that I'd not buy a unit from someone that hadn't read and Understood what Bedini was sharing.
    Now if someones selling the PCB etched already for this thing, I'd be interested in that.
    Gene
    Zenzete,
    The DS815 spectrum analyser would be required to verify the unit you purchased is outputting the signal shared on the DVD's by John... Otherwise you have to trust the Vendor that his sold unit does the same thing Bedini noted it did.
    Gene
    Quote Originally Posted by Gene Lamoreaux View Post
    Gene
    Gene,
    the unit Aaron sells and the units we sell (same unit) are made directly by John, the device on the DVD is a bit different than the one being sold by John to us. (the guts are a bit different, the oscillator is the same) you need sine wave input for the generator being sold, and the frequency noted on the unit we sell is 10 to 150K. you may go to 150K but 70 will work just fine, really depends upon the frequency you want to hit repeatedly . the unit it the book is an earlier version made in time for printing and for release. but the units we sell are more advanced internally.
    I know because I have worked with both styles and helped work on a surface mount version also. I currently am running the book version, using a sine wave input to 70 K
