Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 118
Thread: Bedini RPX Sideband Generators
    1,456
    Perhaps I shouldn't but I'll throw some spaghetti at the wall. Well, I got nothing, how is this thing discriminant? If you say resonance, what is resonating? The obvious candidate would be DNA, the DNA acts as some sort of antenna leading to a building standing wave at the gHz frequency specific to a pathogen that makes a bug go kerploof. I was behind that in that in more complex organisms the DNA is usually enfolded (histones, epigentics et al.) while in more simple organisms the DNA would be out there to resonate, then I thought of mitochondria. I am not expert, but of course mitochondria have their own DNA, less controlled, regulated and folded, than that in the nucleus, much more like a bacterium. I don't know what JB presented, maybe he was trying to get across a way to purify water with this thing, but if one could, which wouldn't be easy, I would try to look at the mitochondria first. And no I am not saying oh this must be harmful, ascorbic acid somehow discriminates, as voluminously documented in the literature, between nearly all pathogens and all toxins and I have no idea how. Nobel prize winner Svent-Gyorgi who discovered Vitamin C felt it went back to the electron transport chain in the mitochondria. So if you could see whether this fries mitochondria, you would have an idea, though not firm, whether it is discriminating against single cell versus multicell. If it doesn't harm mitochondria, which I suspect, then one is back where I started, which is what the heck? Likely just some possibly tremendous health break through that can hardly be evaluated on a shoestring. Que Sera, sera.
    https://www.youtube.com/watch?v=i5sqJNFFwqc
    As far as mitochondria, I can tell you that they are specifically stimulated by red & infrared around the 660-880nm range or so. Red and Infrared will kick them into high atp production mode.
    I don't know if that can be used as a basis to calculate the frequency of red and infrared and see how that compares to the 3.1 MHz fundamental in the sideband generator or if the wavelength of the red & infrared are even relevant.
    Aaron,
    I had some questions when I purchased this item. Since your response was to steer me to a forum I will ask again.
    1. Why does the power input indicate that it requires 15volts?
    2. Where do I find an amplifier that will raise the output power to a level that will drive a plasma tube? I believe Rife used 50watts and the modern systems such as the Rife-Bare system uses up to 300watts. The commercial amplifiers that are available, mostly for the CB communicators, are designed with notch filters that suppress all the harmonics. This destroys the Rife Effect that is sought. The Rife-Bare system used an amplifier that had those filters removed but this is designed for a carrier of 27.1 MHz and the carrier now used is 3.1MHz. These are at opposite ends of the HF scale of 3-30MHz. The amplifier does not function with the 3.1MHz carrier.
    3. What is the power output rating for this device? Why is so much secrecy surrounding this thing? The Rife secret has been exposed since 2008 and other people have devised systems to use it. John Bedini has designed a circuit that evidently produces a broad harmonic field with harmonics that are more robust than usual. This is the idea that was used by Hoyland when he designed the Ray Beam Rife machine that has not duplicated since. The Bedini device uses sine waves where most of the modern Rife devices use square waves. That is the reason I bought it. The square wave folks deplete the energy of the harmonic in producing too many useless harmonics. This is the shotgun effect. Yes, there is a better chance they will hit the target, but it is ineffective because there is not enough power available at that single point to deactivate the pathogen. These waste the power of the device and cause the designer to use 300 watts where Rife used sine waves and was more precise and used only 50 watts to gain much better results. However, without measuring and increasing the power out, which I can, this device is will not replicate the Rife Machine. I doubt that what I received has a power output of 50 watts with 12 (15)? volts in.
    1,456
    Quote Originally Posted by zenzete View Post
    Aaron,
    1. The recommended battery here works fine - https://www.amazon.com/Talentcell-Re...g=maimounas-20
    2. You need a linear amplifier and we may make these available later. There are some small prototypes John made but we might not make them available. Until then, I have no recommendations.
    3. The output is only a few watts. I don't think there is a lot of secrecy around this - everything is disclosed in the book/dvd set. We can't discuss pathogens, etc... because this is only an experimental device with no claims.
    zenzete,
    the device you are describing is called a MOPA to drive a rife tube. they are expensive to build and dangerous, the power supply is over 600 volts. a side band generator is a RF device, anything above the wattage the device produces would get you in trouble with the FCC having an unlicensed radio broadcast.
    Tom C,
    That is not true. A MOPA is a Master Oscillator Power Amplifier. I am talking about a linear amplifier that will feed into a plasma tube. The power supply will actually be over 1200 Volts and the FCC will probably not interfere based on my operation of a Rife-Bare device that puts 300watts into the plasma tube. I have used this for over 12 years and the FCC has said nothing. The entire device will have the function of a MOPA but there is a difference. My new amplifier will produce between 50 and 100 watts out, well below what I have been using. This operation is not being done by just me, there are hundreds of the Rife-Bare devices in operation and many have converted from the old carrier of 27.1MHz to the new 3.1MHz that is being used. The particular frequency allocation for the device will be 3.1MHz and that falls into the Radiolocation area of the FCC Spectrum this area is used by radar and allows Part 15 Devices and has a lot of noise. I believe the absence of an antenna and only spurious emanations from the plasma tube will be well below the FCC observations. The Rife-Bare device that I have been using used 27.1MHz as a carrier and that was not a problem. Worst case I can move to 3.5MHz and operate in the 80 meter range with the CB radios that populate this band. Basically the device in question does not radiate on an antenna. That does limit the range regardless of the internet stories to the contrary. I posted another reply to this thread and do not see it on the site. Was there a problem or did it not post properly? I will repeat the post if necessary but I would prefer not to.
    Aaron,
    1. You did not answer my question. I am trying to find some information about this device. Since you recommend a 12 VDC power pack and the power input is labeled 15 VDC I am trying to determine the range of the input voltage. I have several sources of DC power and would like to know what will and will not work.
    2. I am aware of the amplification need. If I can not find a suitable amplifier to purchase I will construct one. It will only require an output of 50-100 Watts and without the filters it will be simple.
    3. With the 12VDC input I knew the output is quite small. I followed the link provided to http://emediapress.com/ and found no information about this device. Can I choose any of the books or DVD's on that link? You speak of a book and DVD that discloses the needed information. I have not been provided that link. I am sure you can provide a link or the information needed for me to access it. I would be obliged if you would forward that information to me. Thanks
    Aaron,
    I have written and posted two replies to your last post directed to me and neither have appeared on the forum. I will attempt again to ask you these questions.
    1. You did not answer my question. I realize that you recommend a 12VDC power pack, in fact, that is the reason I questioned the 15VDC label on the power input. Evidently there is a satisfactory range. I have several sources of DC power and need to know which will work.
    2. You talk about a book/DVD that explains this device. Please send me a link or direct me to this knowledge. I saw that I could download a book or DVD with the purchase of this device but wanted to download a book that would assist me with this equipment. I went to http://emediapress.com/ that was provided but found nothing about the Sideband Generator. I will defer on my response to your statement about secrecy.
    zenzete,
    Here is a link to Johns book and DVD, you can only get them from Cheniere
    http://www.energyfromthevacuum.com/B...ediniBPRX.html
    Tom C,
    its not a matter if the FCC says anything its a matter of whether or not it is out of compliance, I know guys that have been using CB radios with huge hi watt output sections, makes the old TV sets go all wonky when they key. never seen one of them busted, but its still illegal to go over 5 watts with a CB radio (at least I think its 5 watts) if you are not interfering with other people I don't imagine you will ever get a knock on your door, especially if you are not radiating with an antenna. however, you cannot sell a device of that size output without a license. at least your not supposed to.
    Tom C,
    Thanks for the link to the book and DVD. I have asked for that link and for other information on three separate occasions from Aaron but none of my messages have been approved for posting or answered. No explanation has been given. The Rife information has been known since 2008, but I would like to see what Mr. Bedini has made of it. He is very creative and may give me information that I have not considered.
    You are correct in the statement that you made concerning the FCC legality. There is a low limit output that is dictated by the FCC that cannot be enforced. I have turned my Rife-Bare device up to 300 watts and using a TriField Meter I lose the signal at about 30 feet. I doubt that in the midst of radar equipment and Part 15 devices that anyone will detect my 50 watt signal emanating from a plasma tube. I have adopted a practical outlook of regulations based on reality. Most repressive regulations are used for repression not safety or order. That said, I appreciate and respect your viewpoint. I don't intend to sell anything but you are correct on that point also. The exception to enforcement of the law is found in the personal use clause and the point of non-interference. If the signal is not detected outside your property boundaries and the device is for personal use or investigation, the federal agencies seldom take action even when they are aware of the device. If viewed from a legal point, anything can be done to prevent your investigation. The persecution of Royal Rife is a fine example. The control of the country cannot be in the hands of the people when they fear their own government.
