Ordered a hex rod with 1" flats for the shaft
Will machine it with 1"D ends for bearings and coupling.
The Newman machine saga begins.
bro d
bro d
It looks like this company is well able to produce perfect Newman coils.
200lbs of #38 in a pair of coils that are sealed like rocks.
Doable.
bro d
http://www.stangenes.com/custom-electromagnets.html
Gathering what I need to make a Newman motor that has the same dimensions as the Geoff M's build sheet except for length.
I got a hex bar shaft that is machined for just 4" of mags. Chose 4 x 1 x 1 neos (#45) They are brutal to handle.
It seems that the configuration of 3 norths together and 3 souths on the other flats, is a very difficult arrangement.
The mags very forcefully resist this arrangement.
I've cut a jig that goes around the hex bar and will only allow the mags into the proper slot.
Getting them in and secured is another matter.
Anybody done or doing this?
Wound coils of 60lbs of wire (I know, 200lb is required for the newman effect).
I'm setting up for the full blown motor except I'm doing this shorter one first.
Can get a lot of bugs out this way.
thanks bro d
Much respect for a big job.
I put 6" x 1" x 1" ceramics together by machining the rotor longer.
When I got a magnet in I pushed it almost half way out the other end then secured it.
This allowed the majority of the fields not to interact untill they were mechanically fixed in place. (one magnet did shoot out like a rail gun when I wasnt careful)
I had about 100mm of seperation and then I could push them in the slots by hand.
Im assuming you dont have slots and the magnets are monsters to handle but its the best ive got.
Cant spend it when your dead.
Thanks Deuis,
I'll post pics.
I've got 2 mags in position but not secured.
Made a jig that will hold additional mags in place when positioned.
Got to have complete control of mag when approaching rotor.
I've machined a large window motor rotor in the past that has ceramic mags in slots. (six)
Will check it out for this one.
bro d
Was able to get the powerful neo mags in position.
Made two jigs with CNC router.
1. jig to hold position of mags on hex rotor.
2 jig mounted (used 3 of these) on shaft to hold and position one mag.
this jig allowed me to use tail stock of lathe to drive mag into position, one at a time.
Shaft was mounted in 3 jaw chuck.
bro d
I'm not sure if 99% of the people reading this understand how bloody hard that must have been to do.
Take a bow.
Thanks for the kind remarks.
Thinking about what it will take to install 28" inches of mags on a full length shaft.
Right size steel hex tubing with 1" ID for shaft and maybe in sections.
Next: put a 2-3" wide wrap of fiber glass and epoxy around the middle before removing the rotor jigs.
I'm going to take a shot a building a commutator according to this link:
https://www.youtube.com/watch?v=vNC2LfbDutY
Starting with 3"D copper pipe.
