Results 11 to 20 of 21
Thread: Growing food with Bedini/Tesla devices powering LEDs
    Hi all
    BobZilla, yes, I think I will try to run series groups of LEDs in parallel as per your suggestion...can't wait to try it.
    Nityesh, awesome, I can't wait to see the results of your experiments.
    Looks like some good thinkin' going on here--all, very much appreciated.
    I will most likely be at the shop with my son, tomorrow sometime, to begin winding up some coils. I plan to take some pics of my coil-winding contraption and post them for you all.
    Thank you.
    James, somewhere in Idaho
    Best regards
    ~ Padmé Amidala ~
    Tri-Symmetrical Switch as Oscilator Powering LEDs
    Here is the driver circuit modified to drive the Tri-Symmetrical switch as a solid state oscillator, Keep watching this post, because I will upload the modified "Tri-Symmetrical switch" Schematic(with LED mod) and timing diagram.
    This post will be updated soon, to show the full circuit.
    Kind
    Nityesh Schnaderbeck
    Hi Nityesh
    Wow, that looks great. Can't wait to see your other mods and how they are working!
    Best regards
    ~ Padmé Amidala ~
    Hi Guys
    I haven't made it to the shop to wind coils yet. Hopefully, my son and I can get to it over the weekend. I will try to post pics of the coil-winder after that.
    Best regards
    ~ Padmé Amidala ~
    James,
    Some more info in case you missed the info from earlier in the year. Bob was helping me with this project. found on this thread under Phototherapy- Grow Lights: http://www.energyscienceforum.com/showthread.php?t=1010
    Aln
    Aln
    Thank you for that info. It confirms my earlier research, though I may want to substitute Warm white" for "bright white" as I already have enough of the blue spectrum and maybe not enough of the yellow. So I should try 7 red, to 1 blue, and 1 warm white. I appreciate your input.
    Best regards
    ~ Padmé Amidala ~
    Regarding the circuits in post #12 http://www.energyscienceforum.com/showthread.php?t=3243&p=21974&viewfull=1#post21974 "]http://www.energyscienceforum.com/showthread.php?t=3243&p=21974&viewfull=1#post21974 "]http://www.energyscienceforum.com/showthread.php?t=3243&p=21974&viewfull=1#post21974 I have had to make some more modifications to make the solid state Oscillator stable. Here is the schematic again showing the modifications.
    The success's of this experiment:
    * The circuit does oscillate.(driver circuit)
    * Self rotation mode works(driver circuit)
    * All 3 sets of LEDs light up, from the back-spike of the coil. (Tri-Symmetrical Circuit)
    * A capacitor connected across each of the 3 LED sets increases the brightness of the LEDs, the value of these capacitors does affect the oscillator frequency.
    but
    The batteries went flat very fast. It could be possible, with the right coil(with the right specifications), can run the LEDs and charge the batteries, or at least keep the battery voltages frozen.
    The value of C2 and the inductance of the coil determine the oscillator frequency, as well as the adjustment of RV1 and the values of the capacitance of the capacitors connected across the LED sets.
    kind
    Hi Nityesh
    Nice work. I have been doing some research into the oscillator side of this. What do you think about trying an arrangement like this in the oscillator side? It's a totally separate and complete LCR circuit (blocking oscillator) that could better define the frequency. One could replace R1 in this circuit for a pot, and select the desired frequency with the relationship between L2 & C1. One could calculate the frequency and wind the inductor on a small bobbin with a duplicate coil right next to it on the same bobbin and hook them up with opposite polarity. I'm already designing that on another bigger project, but the oscillotor section would fit into anything (relatively speaking--as one may need to consider wire size for a particular project).
    Attachment 4848
    Best regards
    ~ Padmé Amidala ~
    Hi all
    Here is the link to the photo album with pics of my coil litzing contraption I stated I would share with you:
    http://www.energyscienceforum.com/album.php?albumid=92
    And, here is the link to the photo album with pics of the grow lights I built out of 5 meter long 12 volt automotive LEDs (this set had 7 red to 1 blue LEDs):
    http://www.energyscienceforum.com/album.php?albumid=91
    Can't wait to get a new-and-improved set, with a ratio of 7 red, to 1 blue, and 1 white in a more suitable arrangement, running off of one of these devices...
    The plan is to have four 4-foot long fixtures, on a 6-foot high by 4-foot wide by 2-foot deep shelving unit--one fixture per level, growing food..
    Y'all oughta think about doing that as well...as I think the time is probably near, when you will have to do something like that in order to stay healthy/alive...just sayin'...
    Best regards
    ~ Padmé Amidala ~
    Hi James,
    Thanks for sharing your work. Sure looks like you put a lot of thought into that coil machine. Something else you may want to consider with your LED grow system. You can add in some solar cells to capture a bit of energy back. You will not get great returns from it but for example when I did this I got some of those small square cells and wired them up in series to get 13v, then I used that to charge small stuff. You do not want to go too crazy with it because you do want the light to bounce around for your plants but putting a few cells around the top edge and a few around the sides can be beneficial. Why use the energy once when you can use it twice ehh.
    Nityesh,
    I also thank you for sharing your work. I am still wrapped up in my own project so for now I can only anticipate the day I can replicate some of your work but it is very kind of you to share.
